15X8" or 15X10"
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazin Ed, May 22, 2002.
  1. Blazin Ed
    Blazin Ed Registered Member
    Mar 29, 2002
    92
    Seattle
    15X8\" or 15X10\"
    Got a 4" lift w/ 8" wide wheels mounted on some Pro-Comp 35/12.5/15 MT's but I'd like to move up to 10" wheels. I'm sure others have this setup so I was wondering if you're experiencing any rub up front on street driving? Compressed? What's your backspacing?
  2. GRINCH
    GRINCH 1/2 ton status
    Jan 30, 2001
    1,951
    Helena, MT
    Re: 15X8\" or 15X10\"
    There has been some discussion on 8 or 10" rims, I guess it will also matter if you plan on airing your tires down. I heard the 8" holds the tire to the rim better. Some have also said you will rub more with an 10" rim. I'm in the same boat... I have 33" on a 10" rim and am cosidering going to a 8" when I get my 35".
  3. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    with my 4" and 35's I would sometimes hit with the 8" rims, but with the 10" rims I hit the fenders every time I turned in the driveway. I trimmed a little to eliminate this, but now with my sway bar disconnects I will sometimes hit again, guess I need more lift.
  4. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    8" - you should have rubbing only under serious flex.
    10" - you'll rub turning sharp corners..period.
    I have 38's on 8" wheel with only 7" of lift and I have NO rubbing at all, even when flexing it. If I were to go to a 10" wheel, I'd have to run 35's or 36's max.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    10" looks way better.
