15x8 or 15x10
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by reddog64, Feb 6, 2001.
  1. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Should I look into getting 15x8's or 15x10's??? What are the pro's and con's of each...
    Um... yes officer I know it's too big...
  2. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    What tires are you running? That is what determined my running a 12" wheel.
    Later
    Have you driven OVER a Ford lately?
  3. reddog64
    Nov 9, 2000
    3,325
    I'm running 35x12.5xr15 bfg AT's and love them
  4. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    If you run 10s on that tire it will flatten out your contact patch as compared to the 8. With the 8s the tires will ride just a little higher than with the 10s. I would go with 10s jus to give a little sidewall bulge and a fatter stance.
    Later
  5. If you air down off road then an 8 helps hold the tire on the bead beter.Their's my nickle.
  6. MICHIGAN BLAZER
    MICHIGAN BLAZER 1/2 ton status
    296
    Middleville Michigan
    I like the way 10's look better than 8's w/ that size tire. The 8 will hold the bead better but i've had bad luck with my tires wearing funny with the 8's ....i run 10 wide
    <font color=red>MICHIGAN BLAZER
    <font color=green>89 Fullsize Blazer
    87 Cherokee
    65 IH Scout
  7. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    10s if it's on the street and 8s if it's on the trail.
    Durant, Ok
    I love my SAWZALL!!!
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I like the look of 10's better. But the edges of the rims will get chewed up if you go rockcrawling. 8's seem to be pretty well protected by the tire. For mostly mud and street use, I'd go with the 10's. For rocks I'd probably go with 8's.
  9. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    10's look better on the street. I'm running factory aluminums with Champion beadlocks and they come up just shy of 8". They work great with a 12.5 wide tire and the rocks don't have lunch on them.
    Steve Frisbie
    [image]http://albums.photopoint.com/j/View?u=1191682&a=8779286&p=28489343&Sequence=0&r[/image]
