15X8 Steel Wheels??
Discussion in 'The Garage' started by IDGMC, Jan 3, 2007.
  1. IDGMC
    IDGMC 1/2 ton status
    Feb 18, 2000
    150
    Idaho
    Ok in this age of Bling Bling, I'm a bit of a throw back. I like the look of the old school Chevy Hub caps on Steel wheels. Does anyone make 15X8 8 lug rims that hubcaps would work on? Just your good old solid rim??
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    If you drilled the hubs for a larger metric stud , you could use late model 8 lug caps with the threaded lug nuts to accept the plastic hubcap nuts . You would need to make a hole for the fronts though so the locking hub comes through .
    This would work for any 8 lug rim , including some aluminum aftermarket ones .
  3. IDGMC
    Feb 18, 2000
    150
    Idaho
    Yeah but I want the good old metal chevy hub caps, with pizza cutter tires
