16.5, 16, 15
Discussion in 'The Garage' started by BowtieBlazer, Sep 11, 2003.
  1. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    No time in my nearest dreams did I plan on having to swap in a 14bolt, still dont want to really but the opportunity and time has come to bulletproof another part of the truck....what are the delimas behind the different wheel sizes in general, I know all the grinding and other tech if I ever swap in a d60 front, and I plan on 8 lugging the front d44 regardless. Prices on tires seems to be higher on the 16 and 16.5" rims, what else should I be aware of?
  2. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    16" tires are very limited in size availability as you go above 35".
    Even with an 8 lug D44/10 bolt you may need to grind the caliper bracket to fit 15" wheels (see member tech section previews for article on what needs to be done).
  3. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> If you run more than 3" or so of BS on a 15" wheel you have to grind on even a D44 or a 10b 3/4 ton. You are also limited to steel wheels, aluminum ones just plain won't fit.
    16" wheels have pretty limited sizes available, although you can get military style tires for 16s also, which can be found rather inexpensively. You can go steel or aluminum with 16s.
    16.5s are a good choice because there are lots of different sizes available for them, the problem is that they don't hold on to the tire very well because of a different bead style. If you don't air down your tires then this won't be a problem, but if you do air down you're limited to about 18 lbs before you risk popping beads. You can go lower but you have to be real careful about turning hard or putting excessive sideloading on the tire. Hummer wheels are a good way to go due to the double beadlock design, but you have to deal with getting the backspacing changed on them and the fact that it's hard to find anyone willing to balance them.</font>
  4. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    I'm ordering a set of these for my K5. John is real easy to work with and makes some real nice wheels. Check them out and give him a call. /forums/images/graemlins/thumb.gif
    Eric
  5. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    15" rims are (duh) smaller... so they are a little further from bashing rocks at low psi. They weigh less. They cost less. They have the biggest selection of tires available. They have a safety bead (unlike 16.5s!). All you have to do to enjoy all this wheel goodness is grind the calipers a bit. Ive done it twice... its really not that big a deal. Only reason I would ever run anything other than 15s would be if I got rockwells. /forums/images/graemlins/grin.gif
    j
  6. txtough
    txtough Registered Member
    Aug 31, 2003
    39
    Lubbock Texas USA
    I'm in the same boat, I know I will have to grind the D44 for 15" wheels but what about the huge drums on the 14 bolt? Will a 15" rim fit over them?
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes it will. For the five millionth time, yes, 14 bolt drums will fit 15 inch wheels.
    Depending on your backspacing, grinding a front 44 or 10 bolt can be a big deal. Mine sure was.
  8. txtough
    Aug 31, 2003
    39
    Lubbock Texas USA
    Thank you so much for your kind help I hope that it was not a burden to you. I did run a search before posting this question and did't get the answer I needed. I appreciate your help it saved me lots of time.
  9. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Dude...WTF is that? You need to learn some tact. Despite what you seem to think, You don't know everything.
  10. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    now if all else fails then stay with your 15" rims for now and when you go 8 lug in the front, sell them and get the new rims and tires then...these will keep you at 6 lug...
