16.5 or 16" wheels?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by misfit, Aug 7, 2000.
  1. misfit
    misfit 1/2 ton status
    Jul 21, 2000
    324
    south central wa state
    16.5 or 16\" wheels?
    next spring ill be putting 3/4 ton axles under my 74 and am tryiung to decide which wheel......the market has a lot more to choose from in the 16.5 size, but ive heaard that they debead themselves rather easily. can a ff 14 and d44 accept 15" wheels?
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: 16.5 or 16\" wheels?
    I dont know about the 14FF, but I would have to say yes. My friend is running a 71 3/4 ton with the larger rear brakes and a funky looking FF(Rockwell, i think) he is running 15x10 wheels all the way around, all he had to do is grind a little off the frnt calipers. I am not sure which back spacing he has though, but the tire dont stick out past the fender wells.
    I have heard the same thing about 16.5's... I would go 15.
    Mike [​IMG]
    1982 GMC Jimmy - <font color=green>Emmett</font color=green>
    http://emmett.coloradok5.com
  3. Re: 16.5 or 16\" wheels?
    Emmett I guess your as busy as me toay!!LOL
    On the subject of the wheels,the 16.5 dont have the lip that
    regular wheels have to hold the tire on the rim where the beed is at.They are bad about keeping tires on rims when aired down.
    IF IT AINT BIG IT AINT BAD!!!!!!
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    Keep in mind if you run 15" wheels, you can only use steel because alum is to thick. I run 16x10 with 36" swampers, but selection for tires is slim although getting better, you can now get 38x16x16 Baja Claws - could be my next tire.
    Steve Fox
    90 3/4 ton K5
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I've converted my Jimmy to 3/4 ton and I'm using the 16.5" rims and 35x12.5 General Grabber MT's. I wheel my truck with as low as 16 psi on the rocks and hav'nt lost a bead yet. Mind you I stuffed the Generals on 16.5x6.75 stock steelies, the narrow rim width has'nt been a problem for handling or tire wear, and the tire stays where it belongs. Not only that but the rims are real cheap to replace if you bash one to hard on the rocks (I've got 3 spare rims, all free). Besides I kind of like the hub cap look.
    Rene 81 Jimmy,350,SM465,FF14 bolt,HD Dana 44,3.73's,4"susp.,35"Grabber MT's,body in progress
  6. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
    The 16.5's do have less "grip" on the rim, due to the lack of the "safety bead" that is present on 16's and 15's. 16" steel rims will fit for sure, prolly also aluminum. Steel 15's fit w/grinding on the calipers. I would try for 16's if you can find the tires you like.
    I run 12 psi in my 35" boggers on 16.5x12 rims w/o problems. I also have run down to 10psi in my 35" BFGs on 16.5x9.75 rims w/o ever popping off, but 10 psi was in sand.
    Squash
    http://www.trailrunners4x4.org/users/realsquash
  7. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    Just looked at National Tire & Wheel ad in the Sept edition of 4Wheeler and it says that there's a 37x12.5R16 coming soon for the Super Swamper SSR. Just another option..
    Brian
    89KBlazer
  8. k5stroker
    k5stroker Newbie
    Aug 7, 2000
    3
    Chattanooga, TN
    I run 15x10 steel wheels on mine. I have a FF 14 bolt and Dana 60. No mods were needed for the rear but the front calipers needed some grinding. I say go with 15's.
    '86 K5, 383ci, SM465, Dana 60, 14 bolt, 35" BFG's
