16.5 rim ?s
Discussion in 'The Garage' started by big dan, Feb 5, 2006.
  1. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    Ive decided to swap in my 3/4 ton axles soon and i need new tires. i was originally planing on 35s with rims from summit but i kinda like the idea of 37s but can only get them in a 16.5inch rims size. that would work out because i already have the stock rims but im worried about popping a bead. what is the lowest air pressure i could safely run and are there any ways to keep from popping a bead without beadlocks? thanks
  2. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    DONT air down lol.
    if you use the search you can find a ton of chatter on this.
    with out beadlocks a cheap way to mod your rim is to weld 1/8th rod around the bead seat, this would make it harder to slip the bead off.
    I would also sugest readding up on the hummer tires it sounds like you are planing on, make sure they will work for you, they seem to have a lot of draw backs.
  3. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    i ran 38x12.50x16.5 swampers on 10" wide rims with my old truck . it was 6500 lbs + in weight. i never had a problem at 25 psi in any type of driving.
    and lots of choices in 15" and 17" rims and tires. with 15" just need to grind a little bit on frt calipers nothing to bad.
  4. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    thanks for the replies. i have been searching and have found a lot of informadtion but I still dont know what i should do. im thinking i will probably end up just buying new wheels and 35s. oh and the tires i am looking at are actually from high-tec retreading.
  5. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    i just read that factory chevy 16.5 rims, which is what i have, have a safety bead. does anyone know if this is true?
  6. sweetk30
    Nov 1, 2004
    25,536
    533
    ahh dont think so. if you have the tire off look for a little lip around the bead area about 1/4 to 1/2 " in from the outer edge.
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    I've aired down to ~10psi w/ my 16.5's for a snowbogging trip. It wasn't that much of a concern becuase we had ratchet straps and air if I did like I thought we would. I never did blow a bead though, I was suprised.
    Either get steelies and weld in a beadlock, get hummer rims and re-center them, plan on running 20psi+ all the time, or don't get 16.5's.
    That being said, I just picked up some Hummer beadlocks so I have some 16.5x12 Aluminum rims for sale :D
    Mike
  8. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,005
    838
    Pinckney, MI
    Any vendors that make a decent cheap weld on bead lock??? I have 3 free 38.5 that are on 16.5s so I planned on just getting two new for the rear running the steelies.
  9. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    ok, Ive finally got 3/4 ton axles and I think im going to use the stock 16.5x6.75 wheels with 35x12.50s. I know that there are several people here that have a similar setup. everyone keeps telling me that it will cause the center to wear out faster then normal and everything I find on here goes both ways. can anybody tell me for sure and how much faster it will wear out then normal?
    thanks
  10. big dan
    Aug 1, 2005
    2,656
    29
    Arkansas
    can anybody please help me?
    I want to order tires this weekend and it would be cool if I knew this.
    if nobody can tell me then I will just try it but I'd kinda like to know if anyone could please help me.
    thanks
  11. Bushido
    Bushido Registered Member
    Jan 25, 2006
    38
    Hawaii
    I'm running 35x12.5s and 33x12.5s on 16.5x9.75 rims on two different trucks and never had a problem.I've aired down to 20psi with no problems,in the sand though.---The fact that I just said that is a sure reason to blow all four off the bead this weekend with my luck.:rolleyes: I'm sure the contact patch will be affected if run on 6.75 rims but since you got the rims allready,why not try?
  12. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I make weld on beadlocks and cheap is a relative term.
    I will also be finishing up a write up on how to do the rod inside the rim in the next few days that makes these 16.5 wheels much more wheelable.
  13. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    Bad idea to put that wide of a tire on that skinny of a rim with a 45* bead. Just because it will mount up does not make it a good idea . You might want to look at another option.
    Tom
