16.5 rims and tubes
Discussion in 'The Garage' started by arq, May 13, 2002.
  1. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    anyone running tubes on their 16.5 rims. i would imaging that this would eliminate the problem with the safety bead on these rims. any comments/drawbacks/etc??
    ARQ.
  2. porboy
    porboy Registered Member
    May 7, 2002
    29
    Poway Ca.
    The only drawback I see is that you won't be able to air down as much because of the possibility of spinning your tube.
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    We run tubes in our 16.5''s on the 3/4 ton. We air them down often but I have yet to go below 12psi. The shop that I bought them from said that the tubes will make the tires build up excess heat, and yes the possibility of spinning the rim inside the tire and ripping out the valve stem is there. I haven't had any problems with them except that I had to drill larger holes in my wheels to accept the valve stem.
