16.5 vs 15's.......pros/cons from users.
Discussion in 'The Garage' started by Brian 89KBlazer, Apr 16, 2002.
  1. Brian 89KBlazer
    Brian 89KBlazer 1/2 ton status
    779
    Ontario, Canada
    16.5 vs 15\'s.......pros/cons from users.
    Currently have 37x12.5R16 SSR's under the Blazer with 0 miles on them! /forums/images/icons/shocked.gif That's right; it's still under construction but they already look too small! /forums/images/icons/frown.gif
    I'll keep them for my on-road/off-road tires but want to get a set of 42x15 TSL's for dedicated off-road tires. The question is; should I get 15" wheels or 16.5" wheels?
    The down side to the 16.5's is the bead when airing down. I know some companies make 16.5" beadlocks but they're $$$! The PLUS side is that they'll go on over the D60 calipers with no problems!
    The 15's can be had MUCH cheaper but the down side to them is running big offset and/or grinding the calipers.
    Any recommendations on which way to go?? How easily do the 16.5's lose their bead? All the time? Occasionally?
  2. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    Re: 16.5 vs 15\'s.......pros/cons from users.
    This is simple. Grind the calipers and get the 15's. I dont understand why you wouldn't. Tons of people are doing it and they dont have caliper problems on their rigs.
    That said, I have 16's on my rig too and 38's are big enough for me.
  3. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    Get the 15's and grind the calipers. This is what I did and I do not have any trouble. Just grind them when there are fresh brake pads on them or you will have to grind them more when you replace your pads. I learned this the hard way.The rears will bolt right on. I run 8 to 10 pounds and have not hade a problem loosing beads. I have seen 16.5's blow off at 18 pounds under hard abuse.
  4. BIGJ
    BIGJ 1/2 ton status Author
    896
    Central Arkansas
    I have been down this same road, and I say don't grind the calipers. I had 16's with 38 TSL's just because I wanted to run wheels that fit without grinding. Yes, I want to run 40's or bigger, but I hate to grind on the calipers or run a funky backspacing to get 15's to work. The biggest advantage of 15's is the safety bead, so if that's the case, get a set of beadlocks for 16.5 wheels. Trail Ready's are a good wheel, I just bought a set of them a few weeks ago. Yes, they don't have an inner safety bead, but most of the time the outer bead goes first anyway. And if it's going to be a trail only tire, why not run beadlocks. Maybe I'm getting too lazy, but I'd rather just bolt on the wheels/tires and be done with it with no "grinding to fit." Yeah, they are a little more than most other beadlocks, but you get what you pay for, and the customer service has been excellent.
    I believe Storm Trooper has a set of 16.5 Trail Ready's and he said he has had no problems with them so far.
    Just my .02
    BIGJ
  5. laketex
    6,220
    North Texas
    lazy lazy
    btw, hope you still have a set of 38's in the corner. I'm working on transportation now.
  6. BIGJ
    896
    Central Arkansas
    38's?? What 38's?!? /forums/images/icons/smile.gif
    Yeah, they're collecting dust as we speak. Those brand new lugs are begging to be grooved with my new grooving iron /forums/images/icons/wink.gif . Give me a hollar when you want to get em'.
    And yeah, I'm getting lazy with the grinding on the calipers. Besides, who really wants shave off all that material everytime they buy new calipers.
    BIGJ
  7. bobsurf
    bobsurf 1/2 ton status
    Jun 26, 2001
    410
    San Marcos, CA
    Did 16's get lost in the shuffle there? Or is there some downside to running 16's that I don't know about. They shouldn't require any grinding for D60, should they? Are there tire limitations associated? Can somebody help a brutha understand?
  8. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Just to let you know, they don't make 42"s in 16" wheels.
    Personally, I would go with Beadlock 16.5"s, since they're trail only tires...or get some wheels and save some money and put the Tirelok system on....I know many who have done the grinding thing with no ill effects, but like BigJ, I'm super lazy as well, so I went with the 16.5"s and beadlocks....
    Boss
  9. Mreetz
    Mreetz 1/2 ton status
    Jun 26, 2001
    1,282
    Subs of Denver, Colorado
    In my talks with tire people and wheels, I've been told the 16.5 is a fad that will not be around and to not waste my time with them. Not sure how valid it was, but, I've been going this shop for years and they seem to know their stuff. Sure they sell the 16.5s like everyone else, they just told me not to invest in the wheels if I hadn't already.
    Marty---
  10. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    I got 16.5 beadlocks from Rockstomper for a lot cheaper than Trail Ready. They are probably not quite as nice but they still do the same thing. You can generally run more backspacing with 16.5's because you don't have to grind anything. This will let you get through some tighter spots on trails. Here's my 16.5 beadlocks w/ 39.5s.
    http://members.aol.com/fileholder03/blaz046.jpg
  11. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    Chad?
    What kind of shackle setup is that on the rear?
    I would go beadlock for sure on a trail only tire. Do it right and keep the grinder in the tool box. My .o2
  12. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    That looks like a stock hanger with a hole cut in the bottom to do a shackle flip to me.
  13. laketex
    6,220
    North Texas
    well go ahead and groove the center lugs if you get tired of watching oprah and eating bon bons all the time./forums/images/icons/laugh.gif/forums/images/icons/wink.gif
    Something like these would be nice:
    http://www.pirate4x4.com/ubb/uploads/GroovedJimmy.jpg
    haha. where did you buy your groover and what's one of those set a guy back?
    My dad's trip got postponed but he told me sometime in the next 3 weeks for sure. I'll give you a few days notice. I'd come get them, but then I'd miss an exciting weekend of mowing the lawn or something and we wouldn't want that.
  14. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    laketex i tried to see the pics of those tires and i cant get in...just a heads up
    Later
  15. laketex
    6,220
    North Texas
    thanks...here's the whole thread.
    <a target="_blank" href=http://www.pirate4x4.com/forum/showthread.php?s=&amp;threadid=6132&amp;highlight=grooving+and+pics>http://www.pirate4x4.com/forum/showthread.php?s=&amp;threadid=6132&amp;highlight=grooving+and+pics</a>
    The ones I like are the ones on Jimmy's cruiser or the scorpion. Just so you know /forums/images/icons/wink.gif
  16. Brian 89KBlazer
    779
    Ontario, Canada
    Thanks for the feedback guys! /forums/images/icons/smile.gif
    I guess I'd fall into the "lazy" category too when it comes to grinding. Don't want the hassle of grinding calipers &amp; I'm not cracked up about the much wider stance that would come with larger offsets. Guess it'll come down to which I'm less bothered by; the fitment issues of the 15's or the cost of the beadlocked 16.5's. As for a fad; Marty, 16.5's have been around forever so while they're not a fad; I guess we can live in hope that they'll sooner, rather than later, be replaced by 16's! /forums/images/icons/wink.gif
    Bobsurf, like Boss said; the problem now with 16's is the limited size of tires available. I want MINIMUM 40" tires &amp; there's nothing out there yet in that size for 16" rims. You may have noted that I already have 37x12.5R16. Just want to go bigger now. /forums/images/icons/smile.gif
    Chad; thanks for the pics &amp; the note on Scott. I saw them on his site &amp; forgot about him.
    I guess I'm leaning toward bead-locked 16.5's now but still have a while to ponder.
    Thanks again for the discussion! /forums/images/icons/smile.gif
  17. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    get 20"rims and run Michelins
  18. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    So I take it that 20" (dubs) rims have a safety bead? Could you run those new fancy crome things that people put on their Navagators w/ like 22" tires?
  19. Brian 89KBlazer
    779
    Ontario, Canada
    Actually mj; that's not off the list of options yet! /forums/images/icons/wink.gif
    If I'm going to pay to have a set of 15" rims made; why not pay to have a set of 20's made to open up all the bigger Michelin Radials as options!! /forums/images/icons/laugh.gif/forums/images/icons/laugh.gif
  20. BIGJ
    896
    Central Arkansas
    Only problem with the 20's is that they are $425 a wheel for beadlocks /forums/images/icons/shocked.gif . One of my friends is considering this option, only because you can get a 46" Michelin for $150 a piece from usa6x6.com. That's a whole lot cheaper than a 44 swamper. But those wheels ain't cheap.
    BIGJ
