16.5 x9.75 rock crawlers
Discussion in 'The Garage' started by TXsizeK5, Feb 24, 2003.
  1. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    What are you guys' experience with 16.5" wheels? I have heard something about the tire coming off the rim when aired down. but I don't intend to air down and keep it as a dialy driver and mudder/beach truck. would 16.5 rock crawlers be good match with some 35" mud terains to put on my 14bff? thanks!
  2. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    I'm running them with my 42's. I hear they can lose a bead when aired down below 15psi. You should be fine if you stay above 15. I'm going with Hummer double beadlocks so I can run single digit psi /forums/images/graemlins/thumb.gif
  3. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    I just planning to have this on the street, sand, and occasional mud, at operating PSI... what like 26-30psi?
  4. evilandangry
    evilandangry 1/2 ton status
    Dec 29, 2002
    105
    Norwood, NJ
    I run 35 12.5 16.5 BFG AT's as a street tire. They are mounted on 12.5 in wide rims. I run 27 lbs of pressure in the winter and 32 when it is warm. That seems to work well, but be sure to check the pressure often, some 16.5 rims, like mine, have metal valve stems that seem to leak real easy.
  5. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    If youre not gonna air down, 16.5's will be fine.
