16.5inch rim selection?
Discussion in 'The Garage' started by chulisohombre, Nov 25, 2002.
  1. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    does anyone know of a 16.5x8 rim that has a 90 degree bead that anyone sells?i called some of the cheaper wheel companies such as american racing and a couple of off brands and also rock crawler.everyone sais the same thing.almost all rim companies make the 16.5 inch rim with a 45 degree bead on it.has anyone had trouble with losing a bead on these rims?i know airing down past 20 pounds is probably the lowest i can go without trouble but can anyone give me any insight? /forums/images/graemlins/smile.gif
  2. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
  3. nvrenuf
    Jan 7, 2002
    13,081
    250
    Mobile, Al.
    All 16.5 rims are made with the 45 degree lip since all 16.5 tires have a 45 degree bead. There is no way to get around it, sorry.
  4. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    SWEEEET! /forums/images/graemlins/thumb.gif
  5. chulisohombre
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    so is there any problems with airing down and possibly losing the bead on the tire.with a 15 inch rim i dont air down past 20 anyway so would i get away with 20 psi with a 16.5 rim?
  6. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    I run 10-12lbs on the sand dunes with my 16.5 tires. Haven't lost a tire, yet, at these pressures.
  7. Mobile_Mechanic
    Mobile_Mechanic Registered Member
    Jul 17, 2001
    88
    Phillipsburg, NJ
    On my one ton full size pickup I run my tires at about 15 PSI and haven't lost a bead yet. Except when I bent the inside bead on a rock at Paragon this year /forums/images/graemlins/crazy.gif. But not because of air pressure.
  8. morphed86k10
    morphed86k10 1/2 ton status
    Jun 25, 2001
    463
    Reno Nevada
    Wow, you guys are real lucky. Between myself and my buddy who has a 2001 Cummins HO, we've blew at least three beads on 16.5 wheels last summer. That was with running at 25 psi at the beach. We are a couple of throttle jockeys, but still. I swapped my 16's on and will never buy another set of 16.5's unless I splurge and go for beadlocks.
