16.5's with Beadlocks
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ChadH82, Feb 11, 2002.
  1. ChadH82
    ChadH82 1/2 ton status
    May 9, 2001
    400
    Stillwater, Oklahoma
    16.5\'s with Beadlocks
    I ordered my 16.5 beadlocks from rockstomper the other day and got to thinking. The beadlock holds the tire on on the outer bead but what holds it on on the inner? Are the inner and outer beads different?
    Chad
    '73 Blazer,383,400,Atlas II,D60/14 Bolt,traclok/detroit,39.5 Swamps <a target="_blank" href=http://members.aol.com/fileholder2meg/projblazer.html>Clicky</a>
  2. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    Re: 16.5\'s with Beadlocks
    you weld on to the outside of the rim.get the rim and tire like they are supposed to be and lock the outer ring and wham you have beadlocks---there is a tech article on the pirate board in the tech section that has real good info and pics. im gonna do this also w/ the rockstomper
    Sun Desert Offroad <a target="_blank" href=http://4x4.alloffroad.com>4x4.alloffroad.com</a>
    83 Chevy, 350, sm465, lincoln locked14ff, (soon to be- spooled dana 60, flatbed,and 39.5" TSL's)
  3. ChadH82
    May 9, 2001
    400
    That was a great article but maybe I should clarify... I know how the beadlock goes on and everything but what about the non-beadlock side of the wheel(the inside). Is it possible to pop a bead on that side of the wheel?
    Chad
  4. SCOOBYDANNN
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    I personally have never heard about that, but anything is possible, i would think that if it were a common problem someone would have done somethig about it.
  5. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    I've heard of people taking 3/16" metal rod and welding it around where a inner safty bead would be on a 15" or 16" wheel i hear it works real good i was going to try it but i've been busy on other projects.
    [​IMG] Sometimes you feel like a nut [​IMG]
  6. ChadH82
    May 9, 2001
    400
    Anyone know where I could find some pics of this?
    Chad
  7. hungryjpr
    hungryjpr Registered Member
    Oct 8, 2001
    21
    SoCal
    SMP is correct - I have a set of 16.5" beadlocks that have the rod welded to the hold the inner bead on better. You can contact Gabe Gile sof Aggressive Offroad (off the POR board) &amp; he might give more info - he's the one that made my wheels. Sorry, But I can't find the pic I took before mounting the tire.
    Matt b
