16.5x10 or 16.5x12 what to do???
Discussion in 'The Garage' started by twoslo4five0, Feb 27, 2007.
  1. twoslo4five0
    twoslo4five0 3/4 ton status Premium Member GMOTM Winner
    Oct 5, 2006
    6,615
    71
    Living in a dump, VA
    Im running 35x12.50.16.5 bfg right now on 10 inch wheels...i wanna buy new wheels should i buy 12s or another set of 10s....
  2. twoslo4five0
    Oct 5, 2006
    6,615
    71
    no one???
  3. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    I'm running 35"x12.50"s on 12"s. Looks good, but then I plan on going with a set of 35"x14.50"s when these tires wear out. If it wasn't for that I would've stuck with the 10"s.
  4. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    stick with the 10s
  5. Cajun4x4
    Cajun4x4 1/2 ton status
    Oct 17, 2005
    889
    Lafayette, LA
  6. AFUFO
    AFUFO 1/2 ton status
    Apr 26, 2006
    329
    Chesapeake,Virginia
    10s too..
    I have 35x12.50x15 , my rims 15x10 and looks nice. Plus the wider rim you go, for the same size tire, when aired down you have a better chance of falling off the bead. My friend ran 35x12.50s on 14 inch wide and ballooned way the hell out there. Unless your going for a wider tire later on stick with 10s.
  7. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    stick with the 10's. with a 16.5 rim you will have a hard time getting the beads to seat on a 12" rim. I run 12" rims with my 44's. I have to use a cheetah tank to seat them. 10's are cheaper and available in more styles then 12's also.
    are you replacing just the wheels? if you are getting tires also I would suggest going with a 16 or 17.
  8. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    <~~ Ill personally forever be sticking with 15s unless i ever have a truck that has huge axles or brakes.
    1: Cheaper rims
    2: Cheaper tires
    3: Its cheaper
    4: More tire flex.. absorbs and contours to bumps/rocks at lower pressures.
    Only downside to a smaller rim is brake/axle clearence, and on high performance(or low air pressure) situations where the wheel may spin inside the tire because theres not enough surface contact. I guess if going bigger than 36-37 you could use a bigger rim for less slippage, and not have much of a sidewall difference. All the brothers with the big rims have crappy high air pressure rubberbands that have no suspension effect.. Cant stand it
  9. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Stick with the 10s. it took me a long time to get my36-13.50-16.5 mounted on my 12inch weld typhoons. Even with a cheetah tank.
  10. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    for anything shorter than a 44" tire, 10" wide is plenty. Hell, there are some guys on pirate etc who run 8" wide rims with 44s. My own personal choice: tires 31-37 = 8" rim, 37-42 = 10" rim and 44s = 12". I'm going to run Eaton 15x10s with my 44s, but the weld on beadlock kit will add a bit of width. It'll be all good.
    As far as the "more sidewall is better" theory... that is not always the case. It can lead to stability problems on side-hills, for one thing. This is why comp buggies tend not to run 15s.
    j
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    10" is the maximum width I would recommend for a 12.50 tire, and for pure function I would think an 8" rim would be the best (though for looks I will admit I like the 10" wide rims).
    For off-road use most of the guys in my club are using rims on the narrow side. I know of at least three guys with 15.5" wide tires (35, 39.5, 42) that are using 8" rims and having really good luck.
  12. AFUFO
    Apr 26, 2006
    329
    Chesapeake,Virginia
    Maybe a skinnier rim would also result in decrease rim damage from wheeling? So the tire takes the beating first?
