16.5x9.75 OEM rims rare?
Discussion in 'The Garage' started by Ned Kelly, Mar 25, 2005.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I'd like to get a set of OEM solid dish 16.5 x 9.75 rims. They do exist, right? Are they rare? Can't recall ever coming across them. What is the backspacing on them?
  2. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Not that rare... you just have to look. I got mine at the bone yard for 10-20 bucks each (couple different yards before I found 4 of them). Just took them off and sold them not too long ago for 75 bucks for a set of 4.
  3. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Do you remember the backspacing? I want to mount 39.5 Swampers on them.
  4. Poohbair
    Jan 30, 2003
    2,139
    Ellensburg, WA
    no clue on the backspacing, but I had my 38x15.50 TSL's on them w/o any problems at all.
    Here is an OLD pic of my rig w/ them on it. I sold them to a guy on this board named IRONNUT I think... not sure if he is still around here or not. If he is, maybe he could measure the backspacing for you???
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have 2 of them, and I'm looking for 2 more. I can measure the backspacing this weekend and let you know.
  6. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Was GM the only one's to make this a OEM rim? Just wondering because Ford rims have center hole that is too small to fit on GM's, correct?
    Thanks for measuring the backspacing when you get a chance.
    Did the military use the 9.75 wide rims? If yes, I could try a surplus place.
  7. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    Ford and Dodge 8 lug wheels both have bigger center holes than GM.
  8. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I guess I got the center hole thing backwards. Thanks for clearing that up for me.
  9. dieselponyexpress
    dieselponyexpress 1/2 ton status
    Jan 26, 2004
    220
    Germany
    I don't think so. In that size range, only 16" rims are used.
    Except for the Hummvees of course. But they're only 8.25" wide with A LOT of backspacing.
  10. divorced
    Jul 20, 2004
    5,115
    I measured on the inside of the wheel from the rim edge to the hub mounting surface and got ~4.75" The wheel had an overall width of about 10.5"
  11. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Perfect! Thanks for passing on the measurements. That's the same bs as my current whitespokes running 39.5 Swampers. Now I just got to find a set.
