16 inch rims on a dana 60 and 14 bolt, possible with out midification?
Discussion in 'The Garage' started by stevos67k20, Sep 29, 2005.
  1. stevos67k20
    stevos67k20 1/2 ton status
    Sep 29, 2005
    140
    Somis
    hey i have a 67 k20 pickup and i am currently running 16.5 rims with 33's and i want to get 16" rims and 35 inch tires. i was looking at the space from my front rim to the caliper and it looks too small for a 16" rim. i do not want to get smaller rotors because my brakes already arent the strongest they could be. thank you :D
  2. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    they will fit, thats what I am running.
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I ran stock steel Ford 16s on my 60 and 70 for a while and they fit fine :D
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    From what I understand, you can even get 15's too fit if you don't mind grinding the calipers.
  5. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I have been told that a 16" aluminum wheel will fit fine, but I haven't tried it yet.
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    What did you swap the disc/caliper from? 16s were stock on a D60 so most likely they will fit.
  7. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    He didn't just swap the brakes...a '67 K20 originally had a closed knuckle D44 up front and an Eaton H052 rear. If he didn't do the K30 swap, a p/o did.
  8. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    16" rims were pretty much standard through the 80's on truck equipped with these axles. I've had both aftermarket 16x10's and stock 16x6.5 rims on my Dana 60/14-bolt with no clearance issues
  9. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    The only real problem with 16" is tire choices....
    15" and 16.5" have WAY more sizing options than 16" does.....and of course now 17" and up are becoming more common as well.
  10. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    I'm running 15's with NO GRINDING The backspacing is 2 3/4".
  11. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I don't even know where to begin...
  12. stevos67k20
    Sep 29, 2005
    140
    Somis
    thanks
    i thought they would be fine, i just didnt look right. i saw on a we site that a 16 inch rim does a lot better than a 16.5 rim while driving with low tires pressures becuase of where the bead sits on the rim. is that true? i also found out that tires for a 16 inch rim are more expensive which sucks because i dont have that much money to spend being that i am still in school. thank you for your respones everyone.
  13. 6.2puller
    6.2puller 1/2 ton status
    Jul 8, 2004
    569
    New England
    The selection of tires in 16" rim are multiplying daily. Many more choices now than 2yrs ago. I would not worry about tire selections being too limitted on a street driven rig. On a trail rig yes the selections get slim in Swampers and boggers but for MT tires their are lots on sizes.
  14. seschev3
    seschev3 1/2 ton status
    Jan 19, 2005
    308
    clayton, ca
  15. stevos67k20
    Sep 29, 2005
    140
    Somis
    thank you for your replies
    hey thank you guys alot lot for you responses, sorry about the rookie question in the first place, but what can you expect from a.......rookie. thats why i joined this web site, to learn more about my truck. thanks again. :D
