165amp alternator
Discussion in 'The Garage' started by RootBreaker, Mar 8, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    Well I may be getting a 165 amp alternator dirt cheap..... from a 1990 chevy truck....
    anyone know if the 1990 has the right harness plug as my 78?? or can I use an aftermarket plug to get it to work on my 78? like the trans sport??
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I don't know as to what style plug it is but the newer GM's use the pontiac style. I am sure it will be easy to plug in.
  3. RootBreaker
    Nov 29, 2001
    5,118
    173
    oh yeah... also if I do 2... able to mount them to the motor... how do you electrically hook them up?
    is 2 needed?
    example... 12k mm winch draws 400+ amps... well 2 of these babies would keep er goin :cool1:
  4. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    It will probably have a CS style plug. You can get an adapter from Delco.
  5. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    I just did this for my truck, you have the knife connector delco style, get a CS style and just splice it into the old harness, brown - Gauges, Red - Exciter wire, Black - Ground. I paid $6 at autozone for it, if you need the part # lemme know.
    I dont think you'd need 2 alt's to run the winch, just to be safe I'd wire it up and tes tit out, see what yuo think, if yer lacking maybe consider it.
    I also suggest some 4 gauge from the battery to the alternator without a doubt!
  6. RootBreaker
    Nov 29, 2001
    5,118
    173
    if it isnt a bother.. yeah the autozone p/n would be appreciated as I have one right around the corner from me....:grin:
    well the guy doesnt have the alternator...
    so I was going to purchase the pontiac trans sport one that is 140 amp... well I went to car-part.com and found one... 1994 chevy lumina van.... so I checked advanceautoparts.com and it shows the same part number for replacement parts between both of those trucks...
    I know that alternators are cheap - $100 but I am trying to keep it cheap as I just started working and dont get a check for another 2 weeks
    $28 to my door for this used and guaranteed working alt!!!! plus if it dies makes a good core
    I love car-part.com as I have also got my eldorado calipers from there shipped to my door for $45!!!!! :cool1:
  7. AkMudr
    Dec 30, 2004
    917
    Alaska
    Therse 2 type sof CS pigtails, Internal fan and External fan, I wouldnt worry about the internal fan plug...I owuld take a pic of mine but my camera battery is dead...unless you wanna see i ton my webcam LOL.
    Made by Caltherm, #08627
    Sorry, It was advanced auto, got 'em backwards :grin:
  8. RootBreaker
    Nov 29, 2001
    5,118
    173
    I searched advanceautoparts.com and it shows up as $17 and no pic.. is this the right one???
    thanks
    Jeff
  9. RootBreaker
    Nov 29, 2001
    5,118
    173
    Ok so I went and bought this connector...
    So cut the red and tie red to it...
    cut black and tie black to it
    however... the brown you list as to the gauges...??? do I need to hook this up?
    my current alt doesnt have that...
    they both have the other singe wire that goes to the stud and nut on the back...
    thanks for the help on this....
    Jeff
  10. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,925
    336
    Fort McMurray, Alberta
    I read somewhere that you have to put a certain rated resistor into the circuit -- Check into that as it would suck to blow your electrical system...
