16x10 or 16.5x9.75?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Jun 7, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Which should I go with when I do my axle swap? I will run a chrome wheel. There really isn't much difference in price as far as tires go. But I see more tire sizes available in 16.5". Should there be anything else I'm aware of when deciding? How bout backspacing on each wheel?
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    If it's a daily driver/show truck either will work but there are more tire choices (I think) for the 16.5 rim, but if you are going to wheel and/or air down your tires, the 16 is the best way to go because the 16.5 has no beadlocks.
  3. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    If you are planning on airing down when wheeling go with the 16" rims. They will hold a bead at much lower presure then the 16.5" rims will.
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'd go with a 16 over a 16.5 any day because of the safety bead lip.
    -- Mike
  5. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    If you don't mind using some mid-70's stock chevy wheels that are 16.5-you could air down because they do have a safety bead. All after market 16.5 wheels don't.
