16x35x15 good mud boggin tire for fullsize?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by chillywilly, Sep 24, 2002.
  1. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    Just fell into a deal i couldnt pass up on these 16x35x15s.Anybody use these for mudboggin?If so what ratio,hp modifications?Wont get to try them /forums/images/icons/crazy.gif till oct 6th lol
  2. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    They will do fine. Your limiting factor will be ground clearance and possibly open diffs. I haven't runn them, but a few folks around here run them on 1/2 ton Chevys with 3.08-3.73 gears, automatics, and 350s. A 4.10 or even 4.56 would be better, especially if you have overdrive.
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Well judging by the size you listed I am assuming they are Boggers. If so, you will not find a better tire for boggin. Bottom line. Bigger is always better for mud but 36 Boggers will do good IMO.
  4. gallup
    gallup Registered Member
    Sep 24, 2002
    8
    Ozark Booneys MO
    boggers are great for muddin, but what gear are you running? If the stock gear and motor is all ya have, better stay way down in low range to keep up the rpms.
    If your original tire was 31 inches tall and you have a 3.73 gear you will feel like you have a 3.30 gear with a 35" tire height. If you had an approx. 31" tall tire to start with then you should run a 4.56 gear (actually around a 4.20 but no such creature so go up one) with the new tire size. This is merely to keep the rpms up about like they were with the stock tires.
  5. blk87K5
    blk87K5 1/2 ton status
    Dec 26, 2001
    1,290
    Lubbock, Texas
    Must fill out profile!! Would probably depend on the texture of the mud you run in. Sometimes it is better to run skinny boggers than wide so you will get to the bottom. A lot depends on the weight of your rig.
  6. chillywilly
    May 26, 2002
    70
    northern maine
    Ooops sorry about the profile lol. kinda new to this.What an awesome site tho.84 chev 350 400 trans 208 dana44 12bolt 3.73s.last run had some 35inch wild countrys ran 4lo tached about 7 grand all the way,just ran out of tire /forums/images/icons/frown.gif .Almost droolin waitin to try out these boggers!!! /forums/images/icons/grin.gif
  7. blk87K5
    Dec 26, 2001
    1,290
    Lubbock, Texas
    We were all "newbies" or "pavement pounders" at one point. /forums/images/icons/wink.gif
