17" wheels
Discussion in 'The Garage' started by 6.2Blazer, Apr 14, 2006.
  1. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    It looks like my next tires will require 17" wheels. I've been looking at all of the places that sell the cheap steel versions, but the backspacing seems to be around 4.5"-5" on all of the 17x8 or 17x9 rims which I'm not real fond of.
    Anybody know of a place where you can get 17x8's with about 3.5" BS??
    I know several of the beadlock companies advertise this backspacing, but I just can't afford $200-$275 a wheel right now to get a beadlock.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I run H2's. cheap and they should do what you want. Look on eBay - here.
  3. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Thanks..........but as I stated on my previous post I am looking for wheels with around 3.5" of backspacing........................
  4. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I had to actually have my 17's made. I bought mine bofore 17" steel wheels were being mass produced. Anyhow I had mine made with 4.5" of backspacing and they work perfect with my set up. Unless you plan to run a really wide tire there should not be a problem with 4.5" of backspacing.
  6. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Back up and I'll dig up some pics like you asked for in your PM.
  7. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
  10. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Thanks for the pics!
    :waytogo:
  11. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Oh, and by the way, I have not had any tire rub that I know of. Next set of rims is Walker Evans beadlocks, 17x9 with 4.5" backspacing.
  12. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I have the Crager Soft 8s and haven't had any problems rubbing with 39.5x13.5 Iroks
  13. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Are they the 17x8's?
    Just to clarify, I'm not concerned about the tire rubbing the frame or anything..........I just don't want the outside body of the truck to be the first thing that rubs against a big washout or rut because the tires are tucked in too far.
  14. DPI
    DPI 1/2 ton status
    Jun 22, 2000
    2,792
    In the Burbs close to Tulsa, OK
    Try MRW. They make beadlocked and non-beadlocked wheels and can do about any backspacing... I priced a set of steel 16x7 wheels for my trailer and they were $89 each. I have a set of Extreme Duty 17x10 beadlocks with 4.5" back spacing on my K5.
  15. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    Okay, so what's everyones opinion on this:
    Option 1 -
    17x8, 4.5" BS
    $225 delivered
    Option 2 -
    17x8, custom BS (probably go with 3-3.5")
    $360 + shipping
  16. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Sorry 17x9 my tires only stick out 1-2" in the back a bit more in the front but I plan on getting wheel spacers for the rear axle to match the front track width. On the front they stick out about 3" but remember that is with a 13.5" wide tire. They stick out enough to have prevented the body from getting banged up a couple of times
  17. camokrawler
    camokrawler Registered Member
    Mar 2, 2006
    47
    Central North Carolina
    does anyone know if you can get the 315/70/17 BFG all terrain take offs from a hummer dealer for free or cheap? to fit my hopefully soon aquired h2 rims.
    that would be cool if they like just stack them out back like a trash pile heheh. and a thanks to those morons who put big rims on hummers so guys like us get cheap rims and tires.
    camokrawler
  18. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    And you can't make a new post because.....?????????:rolleyes:
  19. 6.2Blazer
    Feb 24, 2000
    4,675
    26
    Ohio
    I will be using the same tires as you (39.5x13.50 Iroks).
    The Jegs and Summit catalog both show this wheel in 17x9 as having 5" BS, though you state 4.5" BS........can you verify that you have 17x9's with 4.5" backspacing?
    As you mentioned my concern is preventing the body from gettng banged up some.
