$175 14bff?
Discussion in 'The Garage' started by texrbl, Jul 21, 2003.
  1. texrbl
    texrbl Registered Member
    Sep 14, 2002
    14
    San Antonio, TEXAS
    went searchin for a 14bff today found one from a 1996 4:10 and maybe posi for $550 alittle high for my needs and budget. also found one on a 1980's sub for $175 but i dont know the gears or anything else so does this sound like a good price to yall if i plan on swappin gears and seals ext...
    and give me a list of things to check and or replace befor i swap /forums/images/graemlins/deal.gif /forums/images/graemlins/deal.gif /forums/images/graemlins/ears.gif
    finally gettin rid of that 10 /forums/images/graemlins/thumb.gif
  2. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    Not bad pricewise, but if You decide to pick it up, You should pull the cover, and see what the ratio is, and look to see if it's a Gov. Lock, or open Differential.
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    $175 sounds pretty good, around where I live the price is about $150...
    I would do a brake job on it and replace the brake cylinders as well, put on new oil seals and new wheel bearings. I don't think you would need to do anything to the diff as long as it seems in good order, though I would pop the cover and take a look and put in new gear oil.
    You could do a disc brake swap on it if you want to, but I think the drums work pretty well depending on how much you drive/wheel it. I noticed a huge improvement in braking over my 12 bolt drums wet and dry.
  4. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    oh yeah, mine also has a gov lok in it which actually has held up so far, but I am putting a detroit in it. I got the axle off of truck that was run pretty hard, and I have had it for 1 1/2 years and no problems (yet) from the gov-lok.
  5. texrbl
    Sep 14, 2002
    14
    San Antonio, TEXAS
    thanks for the responses i think im goin to get the 80's one and regear, convert to disc, and replace the seals.
    anymore advise would be great /forums/images/graemlins/ears.gif
  6. Greg72
    Mar 5, 2001
    15,680
    1,391
    642 Days to BB2018
    Something else to keep in mind.....if you're going to 4.56 gears (or deeper) you usually need to buy a new carrier anyway (~$160 through GM)....so if you can beat the guy up over a "Gov Loc 14BFF" that nobody seems to want....maybe you can get a better deal?
  7. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Be patient. Depending on what gears you need, look for them with the open carrier. The money you save with the purchase might just buy that Detroit.
    I scrounge really hard for deals, anyone have a good running 400 sb for like $50?????????
  8. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    find out the gears...3.73 and lower try not to pay above 125. 4.10's around 150 or 175. i think i paid 300 for my van width with 4.56's.
