Discussion in 'The Garage' started by 83 oneton, Oct 29, 2006.
  1. 83 oneton
    83 oneton Registered Member
    Feb 11, 2006
    77
    clackamas oR
    :confused: will a 2wd trany be conveted to 4wd?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    yes, but it will require tearing the whole thing apart and swapping the output shafts. if you're going that far, might as well rebuild the existing trans.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    You have to tear it completely apart and swap the output shafts.
  4. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you don't have to take it that far apart, all you have to do is remove the pump and pull out the input drum then depending on the tranny you just remover a snap ring and the outpu shaft comes out. The only gaskests you need are a front pump gasket and a pan gasket
  5. 83 oneton
    Feb 11, 2006
    77
    clackamas oR
    thanks for the input
  6. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    This is HUGE info for me. I've been dancing around this for a long while, getting a lot of different and conflicting opinions. Is this accurate info in regards to a TH400? I have a freshly rebuilt 2WD that I would LOVE to put into my truck. HUGE thanks for any further info! :bow:
  7. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    im not sure about the 400, this is more for the 700-R4 and 350 tranny, but the 400 sould not be to much different, i can send you pics of the process for the 400 if you want
  8. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    PM waiting for you! Thanks a million!
