19.5's on a one ton?
Discussion in 'The Garage' started by garlicbreath, Apr 22, 2005.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    So I'm thinking, I want to drive to colorado this summer in my 71, 1800 miles one way, but don't want those miles on my 37's SSR's. I heard big truck tires wear like iron, and could come across a set fairy cheap, but they have 10 lug wheels I think. I could always spin up some adapters at work to mate to my 8 lug one tons. But then theirs the offset problem, they usually are duallys right? Another bonus is the tires are taller than my 37's, so it would be like a redneck overdrive. What do you guys think?
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Semi trucks use 22.5 and 24.5 wheels, smaller trucks like the topkick use 19.5 wheels.
  3. garlicbreath
    May 17, 2003
    1,136
    Denver
    Ah, and the topkick tires aren't big enough are they?
  4. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Ive got rims from a P30 stepvan on my rig. The rims were 35 bucks a piece at a local yard, so I got a good deal. The tires I have are at about 15,000 miles and have only worn of 1-2/32" so far. Not bad.
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Might look a little funny, but should work alright (single rear dually wheel).
  6. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    P30 series !!!
    I recently saw a P30 series "step van" with a cummins diesel/th400 setup in a junkyard,it had 19.5 inch tires and rims with the 8 lug bolt pattern just like all the other GM trucks (3/4 and 1 ton)...but it was a dually,I'm not certain if the rims are offset too much to allow use on a pickup or K5...I think they would look cool on my truck!--instant lift!--and the tires on that P30 were like new,nice 8 ply ones..probably could buy them for less than 50 bucks each with rims I bet... :thinking: not sure if they would rub the sheet metal though--wish I could try them on and see... :crazy:
  7. garlicbreath
    May 17, 2003
    1,136
    Denver
    About how tall are the tires on those P30's?
  8. BlueBlazer
    Feb 15, 2001
    1,940
    About 34.5" tall and 8" wide, pizza cutters basically.
  9. odee1
    odee1 Registered Member
    Feb 27, 2004
    50
    will these rims and tires clear the fenders on a 2wd truck? I have a 80 model crewcab dually that I tow my stuff with that I am working on repowering with a 6.5 turbo diesel. Would like to go with a taller tire on this truck, running a 235/85/16 right now. How hard are the rims to find? Got any pictures of your rig with the 19.5 rims installed?
  10. BlueBlazer
    Feb 15, 2001
    1,940
    You would probably want to go with 225/70R19.5s for a 2wd. They should fit, but I can't guarantee anything. They are roughly 32" tall and 9 wide. As for the rims, just call around to yards in your area asking if they have any stepvans. If they say yes, ask them what rims they have. You should be able to find a set pretty easy, at least I did. Hope this helps.
