1969 blazer getting back to stock
Discussion in 'The Garage' started by gladyskristee, Mar 29, 2006.
  1. gladyskristee
    gladyskristee Newbie
    Mar 29, 2006
    Prescott, AZ
    Hey i got a 69 blazer that my grandfather gave me and im gonna start doing some work on it. i figured that i would replace the shocks and leaf springs for my first project. does this sound like it makes sence? and if not where should i start. it has sat for about 4 or 5 years but it runs ok and every thing that is important seems to work 4x4 ect... sugestions would be great. thanks.
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Change all the fluids. Engine oil, Antifreeze, Transfer case, Both diffs...... A tune-up:Plugs, wires, cap, rotor... Maybe even a brake job if needed. Then a lift with new shocks.
  3. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would start with things that would wear out while sitting, if you haven't already changed the fluids change them all of them, rad diffs t-case engine trans grease everything that has a grease zerk on it. From there you have to decide whether to keep it stock or not. I think many things can be improved on over stock. You could make it ride super nice with some aftermarket springs or custom springs(not all springs are created equal) I would replace all the body bushings too this will help on bodywork. Hope this helps
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Fluids.....then bushings (body, spring, etc).....then maybe swap out the front drum brakes for disks. 4-wheel drum brakes really aren't going to be much fun.
    Before too much longer, you might want to clarify if you are really keeping this truck stock or modifying it for offroad. Most of the people here automatically assume that you're planning to lift it and stuff some big tires on it!! :)
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Maybe deteriorated rubber items too.....like brake lines, vaccuum lines and fuel hoses.
    You can pretty much assume that anything rubber on that truck is deteriorated after 37 years.
