1970 c-10 dash with Autometer guages?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by juanblzer, Aug 13, 2004.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I haven't removed my new (actually very old) trucks guage panel but it seems as though I could just enlarge some of the holes to run quality Autometer guages. Has anyone done this. I know Brothers Catalog sells a billet dash for this purpose but that is more bling bling than I need. /forums/images/graemlins/grin.gif
  2. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Here are my AutoMeter gauges.
    Unfortunately the 3 3/8" guage that goes between the tach and speedo is not produced anymore. The smaller holes are enlarged by using a sand paper grinding wheel to remove most of the silver tapered area. Just go slow and test fit as you go. If I recall correctly, the speedo and tach did not require much to fit.
    You can also mount these behind the bezel if you are partial to that method.
  3. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    that looks so sweet... /forums/images/graemlins/waytogo.gif
  4. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thanks. If I can ever get my body guy to finish my truck, I can finally get to put them to use.
  5. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I also did that, with Autometer Sport guages
    like this
    This pic is actually my friend Greg72's gage cluster. He did it first and then I did the same thing.
    When you take your cluster apart you will need to make the holes slightly bigger and or cut out the metal that is in the way. A good tip that Greg gave me was to mount the gages as far down as you can so the 'view' when installed is well more viewable /forums/images/graemlins/grin.gif
    Hope this helps and one day I'll get a pic of how mine turned out too....
    Burt
  6. jeffer
    jeffer 1/2 ton status
    Nov 6, 2000
    113
    Loveland, Colorado
    Yukon Jack,
    Are those small gauges 2-1/16 or 2-5/8?
  7. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I also have Autometers, Sport-Comp. They look great. I have the electric speedo, witch it awesome!!! AND 100% vaccurate. I can get a pic up in a few days if youd like.
  8. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    The small gauges are 2 5/8"
