1970 swing away tire rack
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by stevie, Feb 28, 2003.
  1. stevie
    stevie Newbie
    Feb 28, 2003
    3
    Goldthwaite, Texas
    Any ideas on finding a swing away tire rack for the back of my 1970 Blazer?
    Stevie
  2. daveo
    daveo Registered Member
    Mar 19, 2002
    11
    Masonville, CO USA
    KMA in GA makes a real nice aftermarket bumper w/swing away tire carrier option for 1st gen K5's. Very heavy duty - can easily accomodate 36"+ spare tires. Lots of folks have this product. Plan on waiting a bit and dropping a good $, but the quality and strength of the product is great. I love mine.
    http://www.kenmtn.com/
  3. Rasberry
    Rasberry 1/2 ton status
    Mar 30, 2001
    205
    Orlando, Fl
    I believe I have a stock one laying around. I'll have to go check. I think I might be missing one peice though. It should be easy to make.
  4. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    I got one that I just took off my 71 blazer, its the stock style one. its in pretty good shape and I have all the parts and brackets for it. PM me if interested also will get rid of cheap. cause its just aking up space at the moment
  5. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    TheBlazerKid - I sent you a PM.
  6. vaulter
    vaulter Registered Member
    Mar 3, 2003
    15
    texas
    Any chance of buying that tire rack from you?\
    Steve
    Vaulter
  7. cleszkie
    cleszkie 1/2 ton status
    Apr 23, 2001
    121
    Santa Ana, CA, USA
    Before you buy a stock swing away tire carrier, make sure that your Blazer has the proper body reinforcement plates and welded in nuts inside the passenger rear quarter panel. Blazers that came with the carrier have this already. Blazers which came with the interior tire mount do not have any body reinforcement or welded in nuts. The carrier will damage the body if some sort of reinforcement at the attachment points is not added. Just my $.02.
  8. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    So the rack I took off my blazer, theres threaded holes in the body for the top and the bottom theres a plate that goes on the inside of the bodu panel, this means that it is a stock tire rack? Oh by the way, I have mine if anyone wants it.
  9. vaulter
    Mar 3, 2003
    15
    texas
    I'm interested. I did not have a stock tire carrier on mine. I could see where you'd need the reinforcements. I could make them if I had to.
    Vaulter
  10. vaulter
    Mar 3, 2003
    15
    texas
    do we need to go to the "parts" part of the site to talk more about your tire carrier?
    How big are the brackets? Pictures?
    vaulter
  11. bouncytruck
    Oct 11, 2001
    858
    Bothell, WA
    thats good infor cleszkie. I did not know there were re-inforcement bolts inside the panels. Does anyone have a photo of these plates? I wouldn't think they would be too hard to fab up.
  12. Larry_in_Tx
    Larry_in_Tx 1/2 ton status
    Oct 24, 2002
    404
    Houston Tx.
    I can snap a shot of mine when I get home if someone doesn't post one before then.
  13. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Petrolia,Ontario,Canada but working in Port Huron,
    Here's the reinforcement plate that goes at the rear pass. quarter.The rod angles down to the side marker light enableing you to hold it in place while you thread the bolts into it.The piece is approx 1/4" thick.
  14. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Was that rod added later?? My bracket looks like that, but no rod.
  15. BobK
    BobK 1/2 ton status
    Oct 5, 2000
    1,604
    Possibly the installer attached that rod for his/her convenience.I have no way of knowing what it looked like originally.
  16. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    I never even looked at the nut plate on mine. Thanks for the pic.
    Be careful drilling. Whoever the idiot was who installed my carrier punched a hole through not only the fender, but drilled through the inner panel as well. Dufus!
  17. Rasberry
    Mar 30, 2001
    205
    Orlando, Fl
    This one has a rod too. It probably factory.
  18. easy_13
    easy_13 Registered Member
    Mar 13, 2003
    7
    Kentucky
    Just bought a 72 Blazer, has stock swing away carrier in almost mint condition; however, it does not include hardware for mounting tire. Do you just use a U bolt? Can anyone post a photo of hardware? Thanks.
  19. J.Lance
    J.Lance 1/2 ton status
    Oct 8, 2002
    145
    Arvada, CO
    The stock carrier has a sort of wide U shaped channel about 6" long or so that the tire "hangs" on and then a bolt and nut below that to snug it up tight. Also, just a tip, when I was running a 33" spare while wheeling, the top bracket bolt started to pull through. To remedy this, I drilled the hole out a little larger and clear through the stake pocket and installed a grade 8 bolt with a fender washer on the back side. Absolutely no probems after that. I wouldn't recomend hanging anything over a 33 on a stock carrier, it wasn't designed for it. Best bet for 34" and above is an aftermarket carrier that bolts or welds to the frame. Just an opinion though.
  20. Rasberry
    Mar 30, 2001
    205
    Orlando, Fl
    With the pic you see above, it had an L-bracket that hung upside down that the tire rest on and was held on with a long bolt and nut.
