1972 Blazer help needed
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by BLZN4FN, Dec 17, 2002.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    In found a 72 k5 on Ebay 350/4speed
    what t-case came standerd in 72?
    also I have a corp 14 and a corp 10 3/4 ton ft axle
    will this fit a 72 or do I need to move all the spring perces
    and modify the steering?
    Bo
    Sorry for the stupid questions but all I have ever had are
    2nd generation blazers
  2. blueturd
    blueturd Registered Member
    Dec 3, 2002
    88
    Arvada, CO
    If you go to the Specs link at the homepage it lists what came in the 72's
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    It should have a np205 fixed yoke t-case.
    The front axle will bolt up. Just use calipers for a 69-77 or you will have to chnage the flex lines.
    The rear axle will bolt up if it is from a 1-ton. 3/4-ton 14FF's need to have the perches moved in. I don't think any of them will have shock mounts that will work without being moved.
  4. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    The 10 bolt may not bolt up, I think the spring pads are further apart. GM 10 bolt front axles are not a bad axle, but the D44 is better. It you just want 8 lug up front, put the spindles, rotors & hubs and caliper brackets from the 10 bolt on your D44. They bolt right up. The calipers and locking hubs are the same. The 10 bolt outer axles are the same too so I would save them. The inner axles are different. I have a '70 K-20 and I got all of my disc brake conversion off of a '79, 3/4 ton, sub 10 bolt.
