1972 Blazer Lift Questions
Discussion in 'OffRoad Design' started by 1972Blazer, Jan 6, 2001.
  1. 1972Blazer
    1972Blazer 1/2 ton status
    Jan 2, 2001
    238
    carlsbad, California 92009
    Here is what I am planning and I just wonder if anyone else has done this yet? I currently have a Superlift 4" suspension lift with rear blocks and I also have a 3" Body lift (body lift has to go). I will continue to use the front 4" springs and add the Extended Shackles for a total lift between 5" and 5.5". For the rear I am ordering the 5.5" heavy Duty Superlift springs. I think this should set me about level front to rear. What do you think and has anyone else done this?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I really don't have much input on the rear springs, if they are specifically for an early k5 and have 5.5" of lift, you should in theory be fine........
    It is easier to raise them than to lower them though, so if it doesn't work, it's easy to fix.
    SW-ORD
  3. blazer72
    blazer72 1/2 ton status
    Apr 13, 2000
    939
    KCMO
    Given the same lift spring front and rear on a 72 the rear will be about 1.5 to 2 inches lower with the Hard top fitted. With the Hrad top off mine was still low in the back by about an inch.
    I understand the jeep thing I drive a BLAZER!!
    Ken
  4. smp
    smp 1/2 ton status
    Jul 5, 2000
    708
    Florida
    My 72 saged just like blazer72 i put a 6" front and 8" rear sits real nice
    <A target="_blank" HREF=http://WWW.SMP.COLORADOK5.COM>http://WWW.SMP.COLORADOK5.COM</A>
