1972 Dana 44 axel numbers what do they mean?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by BozoWise, May 15, 2002.
  1. BozoWise
    BozoWise 1/2 ton status
    Mar 28, 2002
    1,224
    Lubbock, TX
    I just removed the cover and here is the scope stamped on the ring gear. I would guess it was made in 12-9-72 but what do all the numers mean?
    12 9 72 DANA 18520 A3035 45-11
  2. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    im not sure about the numbers.are you trying to find axle ratio?if its trhe stock gears more than likely it is a 3.73 to 1 ratio.check your glove box door and it will say there also.
  3. BozoWise
    Mar 28, 2002
    1,224
    Lubbock, TX
    45 is ring gear and 11 is pinion for a 4.09 gear ratio.
    Can you run fulltime with a 4.09 in the front and a 4.10 in the rear?
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    The '77 K20 I had was a 400sb t350/ 203tc and came stock with 4.09f/ 4.10r gears.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can run full time with 1% difference. 4.09 vs 4.10 is a .2% difference...well withen the acceptable range.
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    Yup, I run 4.11 Rear and 4.09 front.
  7. POFF
    POFF 1/2 ton status
    Aug 13, 2001
    221
    San Diego, CA
    I have 4.09 front and 4.10 rear. I talked to my drivetrain guy about it. He said they do that so the front axle pulls the rear slightly. It makes the truck handle better. You are correct on the ratio.
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    They do it just because that is as close as you can get with certain models of axles. The number of teeth on the ring gear, and the diameter of the ring gear dictates the exact ratio that can be achieved with a given axle design. Normal differences in tire wear from front to rear will make a lot more difference than 4.09/4.10/4.11 :1.
  9. chulisohombre
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    you can run 1% difference.which means 4.08 all the way to 4.12 would still be with in tolerance.
