1972 K5 Beast...trade for Daily Driver
Discussion in 'Complete Vehicles' started by luvshack, Dec 3, 2006.
  1. luvshack
    luvshack Registered Member
    Oct 18, 2001
    17
    Bozeman, MT
    OK i've had this for sale here before and i do hate to part with her, but she's just got too much for me and i want a daily driver 72 blazer (show).
    Here are specs. Also if you send me email or call me, because sometimes i don't get notified on responses to the thread. Larry 406-599-7742 or larry_edwards@luvshack.org Can view all pics at:
    http://www.luvshack.org/newBlazer.shtm
    SORRY - the price is $12,500 OBO
    Well it's sad, but I have to get rid of the beast! I am using as a daily driver and its just killing me, gets about 6 MPG. I bought about a year ago and it's everything I always wanted AND more! Probably a little too much for me, as the axels are 1.25 ton and have detroit locker, which is not good for driving high speeds (I did drive from Idaho fine at around 70MPH). This guy definitely turns heads. I have all the receipts which total more than $30,000 in parts. The engine alone is worth around $9,000 and has been Dyno'd at 500HP. Guy told me with blower could get over 1000 HP out of her. I truely love this vehicle but just too old for it I guess. Would consider trades looking for nice pickup like 2001 Ford 250 Lariat (or even prestine 72 blazer that I could use as a daily driver), or other??, but needs to be "NICE" ride (preferably with heated seats!) Here are all the specs, please call or email me with any questions email: mailto:larry_edwards@luvshack.org cell: 406.579.2666
    Engine Specifications
    "Comp. Engine & Machine" balanced & built "496 Stroker" engine, Dyno 500 Hp, 600 ft lbs torque @ 2500rpm.
    Chevy HD 454 block bored .30 over
    New carburator
    9.5 to 1 compression "speed pro" pistons
    4340 forged crankshaft
    “Comp Cams" solid lift camshaft & double chain timing set
    "Comp Cams" magnum steel roller tipped rocket arms
    "Manley" extreme duty hardened valves
    Ported & polished oval port cast-iron Chevy 454 heads
    "Weiand" stealth aluminum intake manifold
    K&N air filter, "Miloden" high pressure/ high volume oil pump & pan
    "MSD" GM HEI distributor w/"MSD" super coil & 8.8mm "MSD" plug wires
    Chrome steel valve covers, timing chain covers & air cleaner
    "Summit" stainless steel braided fuel line & high flow water pump
    "Hooker" super comp. headers
    2 1/2in. dual exhaust
    "Flowmaster" mufflers.
    Large capacity 4 row radiator
    Driveline Specifications
    Front 35 spline Dana 60 1 1/4 ton axle w/Trac-Loc limited-slip differential w/4.56 ring & pinion ratio and heavy duty disc breaks
    Rear GM corporate 1 1/4 ton 14 bolt full floating axle w/ a Detroit locker, 4.56 ring & pinion ratio & heavy duty drum breaks.
    7in. of lift in front & 9in. in rear
    Rancho RS5000 shocks
    35/15.5/16.5 custom cut Super Swampers SX tires on American Racing 589 series alloy rims w/a matching spare
    GM SM465 4-speed transmission
    New Process 205 transfer case w/HD 1350 series yokes
    GM old style cast-iron bell-housing
    "Ram" ceramic clutch
    Custom "DOM tubing" adjustable clutch rod w/heim joint ends
    Custom extreme duty drive shafts
    Miscellaneous
    Body tub had been Herculined inside from the bottom of the dash to over the bed rails,
    Factory options include full gauge package (Fuel, MPH, Tachometer, Oil & Vacuum pressure, Temp, Battery),
    Tilt steering, removable hard top (windshield back).
    Kenwood KDC – X789 CD/MP3 Receiver
    2 – 6.25” Alphasonix Front Round Speakers
    2 – 6x9 Alphsonix Rear Speakers w/custom side panels
    Alpine Amplifier
    Dual Batteries
    6 point full roll cage
    I would be interested in trade for 72 daily driver fully restored
    …The Bad News
    · Rust underneath on both doors (see picture)
    · Dent in Driver’s Side Rear Quarter panel (see picture)
    · Rust on top of bed rail (see picture)
    · Paint fair, but for “show” needs to be repainted
    Also, if i was going to keep her, i would get hydrolic assist steering as well.
  2. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I have seen this Blazer Several times before. The first time I saw it, it was on ebay a few years ago. I liked it so much I saved a picture of it for me desktop. :bow:
    I would snatch this K5 up in heartbeat! Unfortunately we are no where near eachother and I don't have the cash. Otherwise, I hope it finds a good home! ;) :waytogo:
  3. luvshack
    Oct 18, 2001
    17
    Bozeman, MT
    Yes, i really do love her, but i'm over 40 now and just too tough getting in and out of it. I would hate to lower it and remove the axels (detroit locker) etc...but i really want a nice "show" truck and this is a rock crawler beast as it is now. Thanks again and let me know if you win the lotto! :)
  4. black sheep
    black sheep Registered Member
    Nov 7, 2006
    41
    Va Beach
    NICE TRUCK!!!lift it more,bolt on 44"s, build a bigger garage,buy a geo to go to work,and throw away the tv.be sure to buy a garage frig that holds alot of beer
  5. luvshack
    Oct 18, 2001
    17
    Bozeman, MT
    Added pics...still need a daily driver!
    OK anyone out there want to trade?
  6. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    I'll trade you my K10 :wink1:
  7. luvshack
    Oct 18, 2001
    17
    Bozeman, MT
    Well that's a cool step-side with lots of mods, but looking for something a little more driver friendly! :)
  8. luvshack
    Oct 18, 2001
    17
    Bozeman, MT
    OK - if no trades...rock bottom price of $10,500
    I go through this every winter, its just not a daily driver especially in winter! If i make it through another winter, then goody because she is fun in the sun!
  9. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Free bump for you...beautiful rig, and a great price. Hope she sells!
  10. luvshack
    Oct 18, 2001
    17
    Bozeman, MT
    Bump
    Bump
  11. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    Wow you still haven't sold it? I'd think that truck would sell in a week!
  12. fordeater
    fordeater 1/2 ton status Premium Member
    Mar 21, 2004
    1,402
    Missoula, Montana
    man that thing is sweet. Wish i had the money.
  13. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Bump for another 1st gen. :D
  14. MetalMelter
    MetalMelter 1/2 ton status
    Jan 20, 2006
    401
    EARTH/COLORADO
    Someone buy the truck, good investment, never to be built again.
    Long live the first gen.
    Look at the build sheet, Many dallors spent.
    Trade for a dependable DD is a great deal.
    It will help not only him, but youself also....:deal:
    Bump..
  15. Col_Sanders
    Col_Sanders 3/4 ton status
    Apr 27, 2005
    5,688
    KFC
    I'll trade you my wife 5'2" 110lbs, 25 yrs old :laugh:
  16. CDA 455
    CDA 455 3/4 ton status
    Jun 2, 2006
    8,598
    43rd State
    How many miles on the babe :D :p: :haha: ?!
  17. blazindorito
    blazindorito 1/2 ton status
    Nov 25, 2003
    2,047
    Southern California
    Now that is funny...:laugh::laugh::laugh::laugh:
  18. Col_Sanders
    Apr 27, 2005
    5,688
    KFC
    I guess I could say she's low mileage. Has an annoying whine coming from the intake though..
  19. Chevy305
    Jan 23, 2006
    11,232
    490
    New Hampshire
    How about the headlights? Are they real bright?
    :haha: :haha: :haha:
  20. blazindorito
    Nov 25, 2003
    2,047
    Southern California
    That is too funny...
    I would like a bumper like the one you have on the front. Where did you get it at? (pun intended) HAHAHAHAHA
    No seriously Luvshack where did you get the bumper?
