1975 14bff carrier?
Discussion in 'The Garage' started by gone huntin, Apr 2, 2005.
  1. gone huntin
    gone huntin 1/2 ton status Premium Member
    Oct 25, 2004
    1,706
    Coldwater, MS
    What type of locking unit would this be? What type of lubricant does it require? Asking for a friend that just aquired this truck.
  2. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    You'll need to know what locker is in it (assuming from your post is isn't an open dif.) and then you can determine the type of gear oil you need.
    Eric M.
  3. gone huntin
    Oct 25, 2004
    1,706
    Coldwater, MS
    From pics. I've seen on ebay, it's a gov-lock.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Well no matter what posi, 80-90w and limited slip fluid, friction modifier, whatever.
  5. gone huntin
    Oct 25, 2004
    1,706
    Coldwater, MS
    There is a TSB from GM saying NOT to use a friction modifier in the rear diff. containing a G80 in 10 bolts like in my 'burb. It states that using the friction modifier will cause pre-mature wear.
  6. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    That is correct. Gov-locks DO NOT use limited slip additive.
  7. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Since when? Where did you learn this?
  8. Blazer1970
    1,600
    Old Mission, MI
    Since Eaton started making them in the mid '70s.
    Here is a quote from a post on the diesel page where someone e-mailed Eaton for info on this:
  9. gone huntin
    Oct 25, 2004
    1,706
    Coldwater, MS
    Then he should use regular 80w90 in it then? That's what I was thinking, but I wanted to hear it from someone else too. I went to look it up in my ALL-DATA, but it only goes back to '82.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Ahh, well there not that great anyway.
