1975 Blazer Transfer Case
Discussion in 'The Garage' started by LovesDunes, Nov 7, 2005.
  1. LovesDunes
    LovesDunes Registered Member
    Oct 30, 2005
    48
    San Diego
    Hi Everyone. Here is an easy question. I just purchased a 1975 Blazer. The transfer case shifter knob offers no explanation on what is what. Can you guys tell me what all the way forward is. 4 Lo? 4 Hi? I played around with it this weekend but did not seem to learn anything other than it can sure make some scary noises. I'm going to go buy a manual on the way home tonight to learn some more. Do I need to be in neutral to get it back to 2x? Or into 4 Lo? Or park? I kept having to turn the truck off to put it back in 2x. With the truck running and I put it or try to put it in park all kinds of grinding noises were going on. Has nice looking warn hubs up front. I got lots of exercise hopping out turning those things.
  2. Cricket
    Cricket 3/4 ton status
    Nov 29, 2004
    8,224
    Colorado
    It should be a NP203 chain drive or NP205 gear drive transfer case.
    203 pattern from firewall toward seat is: Low-loc, Low, Neutral, Hi, Hi-loc.
    205 should be 4-Low, Neutral, 2-High, 4-High.
  3. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    I have a '75 as well. It came with a 203. I have a 205 knob on mine, great to confuse people. :haha: You do have to have the transmission in neutral to shift the t-case. If the t-case is out of adjustment a little it will make it hard to shift- lots of bad noises! :eek1: Good luck!
  4. supernaut
    supernaut Registered Member
    May 2, 2005
    94
    Seattle, WA
    If it has a NP203 then the locking hubs may indicate that it has a part time kit in it, or that they were put in in anticipation of a part time kit. here is shift pattern info for with and without part time kits installed on a NP203. This info does not apply if you have the superman NP205.
    HERE is a link to the milemarker reviews on this site where I took this quote
    there should be a metal tag on your transfer case that will plainly state what it is. My NP203 in my '75 K5 has the tag on the front side of the t-case above and a little to the left of the front drive shaft yoke. grab a rag and a flashlight. once you wipe it off it should be shiny metal/colored (mine is shiny metal and blue) and easily distinguishable from the rest of the dull grey/mud color of your t-case.
  5. LovesDunes
    Oct 30, 2005
    48
    San Diego
    Thanks guys. I will crawl under it when I can and check out what I have. So back in the day you could actually shift the transfer case into low and still be in 2 wheel drive? That is cool. I wish my F-350 would do that for moving my big ole trailer around.
    Here is a picture of the Blazer out in Glamis before we hit the bigger dunes.
  6. 75GmcJimmy4x4
    75GmcJimmy4x4 1/2 ton status
    Apr 29, 2009
    255
    Los Lunas NM
    im having the same problem with my 75 jimmy i think im just a newb or something ......... shifting a transfer case shouldn't be brain surgery
