1976 chevy with drive flanges???? never seen them before..please help
Discussion in 'The Garage' started by 55Willy, Mar 26, 2002.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    Okay, I finally got my friend brainwashed into getting a chevy, he wants a truck so he can hual his dirt bike. We went and looked at a 1976 today 3/4 ton auto with a rebuilt 350 4 bolt main, has 20K on the motor. It is a TH350 and a NP203. 14FF and a 44 front, although it has drive flanges..can hubs be put on it? The guy is also willing to take $1000 for it, it needs cancer repairs but looks okay on 75% on the rig. drivers side has 3 bad spots. Should he keep looking or walk on by?
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    my dana 60 has drive flanges and yes you can put manual hubs on it /forums/images/icons/smile.gif
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    I thought of your axle when I seen it so I crawled under to see if it had been lucky enough to get a big dog 60! but nope just a 44. He's calling on the one in Milwaukie tomorrow so you might be getting a PM to go check her out. that one up there is only a half ton but I have already located some 3/4 ton stuff for it.
  4. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    cool keep me posted and ill go look at it /forums/images/icons/smile.gif
  5. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    It is probably still full time, J. ALL Chevs with full time 203's looked that way from the factory.
  6. Grim-Reaper
    7,385
    Atlanta
    BlazinOR hit it. The truck is still full time. It has a set of slugs under the caps. pop the caps and the slug out and a standard D44 hub will fit. You need to convert the transfer case to part time before you install hubs.
  7. rodzzilla
    rodzzilla 1/2 ton status
    953
    Grinnell, IA
    The early 3/4ton 44's had the external drive plates. They take a different locking hub. I believe the spindles are different than the later interal hub 3/4's (Not 100% sure), so that would have to be changed to switch to the newer hubs. Just leave the hubs locked in until you switch the t-case to part time. Otherwise, you will have to put the case in the Lock Position.
  8. Md mudder
    Md mudder 1/2 ton status
    Sep 29, 2000
    139
    yep any warn dealer or even summit racing can set you up with hubs for it just tell them you need external mount not internal. just look under milemarker hubs in a summit ad they are listed there.
