1977 Chevy P/U long bed 3/4 ton 4x4
Discussion in 'Complete Vehicles' started by dpmalibu, Feb 11, 2007.
  1. dpmalibu
    dpmalibu 1/2 ton status
    Sep 24, 2005
    388
    Trenton,NJ
    Blue exterior. Has 87 nose. Body has some rust.Floors are 95% solid excpet for one small hole on driver side size of quarter. Also has chrone step tubes on it. Bed has cap on back but no tailgate.Interior is Okay has Sun Pro Gauges. Also has a tilt column.Motor is a TBI motor from an 87 P/U . All Fuel injection parts/sensors are all hooked up and working. Motor runs excellent. No smoke. has Suburban gas tank in rear with factory in tank fuel pump.Bone stock except for Headers with new exhaust turns in front of rear wheels. Exhaust does not leak . Has 700 R4 trans.Trans fer case is NP208. Rear are 10 bolt front with and 14Bolt FF. Has 3" body lift and new springs .Tires are 35x12.50x16.5 BFG MT's mounted on white wagon wheels and black steel wheels. Truck runs awesome no smoke. Just needs a P/S bracket and tighten up tilt column mechanism. Truck can be daily as it sits.Truck does have a class III hitch too.Asking $1000 B/O Located in Hamilton,NJ 08610 (609) 481-8811
    Truck does have a suspension lift as well. Has new front and rear springs and steering arm like I mentioned earlier .Should be 4" lift.Guy I bought it from didn't tell me.
  2. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
  3. dpmalibu
    Sep 24, 2005
    388
    Trenton,NJ
    truck does not need master cylinder. I filled up resevoir and brakes came back. Stops good trhe way it is but I would bleed them.
