1977 K5 / 89 S-truck steering column interchange?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by thedrip, Apr 27, 2004.
  1. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    My 77's column is all kinds of screwed up, one of the bearings in the tilt mechanism ate itself (bearing race came out in pieces). I have an 89 s-truck sitting out back. I noticed taking the column apart that the internals are almost identical (ignoring extra button for cruise and such on the 89, and the lack of a highbeam mechanism on the 77). Does anyone know if the columns would bolt up? I have to fight through piles of parts, animals, and a lot of broken glass to get the column out of the s10 to try, so I wanna see if anyone's tried this first.
  2. dyeager535
    26,980
    The length will be wrong.
    I would suspect that most, if not all, of the internals not related to column length would work though.
  3. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Most GM upper columns are the same length. The lower part, fromthe firewall to box, is where the langth changes If you use just the section from the fire wall to he wheel, It will Physically bolt in. BUT there will be wiring issues. My old 76 actually had an upper column from a 77 T/A in it. I moved the shifter from the column to floor. I had the column already and it was a tilt(with no shifter on it). And the upperpart bolted in and the wiring matched up. Just had to monkey with the Nuetral safty and reverse lights. Which I moved to shiftr anyways.
