1977 Seville brakes won't work will they?
Discussion in 'The Garage' started by clubba68, Oct 9, 2003.
  1. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    1977 Seville brakes won\'t work will they?
    1977 Cadillac Seville rear brake calipers won't work will they?
    Thanks,
    Andrew /forums/images/graemlins/usaflag.gif
  2. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Re: 1977 Seville brakes won\'t work will they?
    Unfortunately, no, they dont support the 3/4 rotor thickness- they could work in the short term but new brake pads will be too thick to fit.
  3. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    This probably isn't good, but couldn't you grind down new brake pads to fit? Won't last as long, but...????
  4. clubba68
    Dec 6, 2002
    1,511
    ...it would be cheaper! (Just thought I would finish that post for ya.) /forums/images/graemlins/thumb.gif
    -Andrew /forums/images/graemlins/usaflag.gif
  5. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Aren't you guys running D60 front rotors. Why couldn't you run the rotor off of a Ford or Dodge Dana 60 rotors that are 1.25" thick instead of the Chevy's 1.5" ones /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/thinking.gif
  6. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    I'd take a pass on grinding asbestoses
  7. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    most are using D44 rotors
  8. Hardcore
    Apr 25, 2003
    458
    New Orleans, LA
    How thick are D44 rotors?
  9. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Seville calipers would work if you install Eldo pistons in them. The caliper castings itself are the same as the Eldo's but with different thickness pistons not allowing the caliper to fit over the 3/4 ton rotors. I am not sure if the pistons are cheaper and easier to get than the caliper itself but if so then it would be worth it maybe. Also the fleetwood calipers would work if the pistons were changed out.
