1980 accelerator cable, superlong, for what engine ?
Discussion in 'The Garage' started by R72K5, Nov 27, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    the 80 parts truck out here had the really super long accelerator cable, i saved it and the pedal assembly too, usually i only see super short cable in these turcks, for the sbc engines
    what engine would the reallysuper long length one be for ?
    VIn code to truck is * CCD14AJ105619
    what engine was original ? engine mounts arein lowest set of holes,
    thanks
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Probably 6.2
  3. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    The "D" in the vin code is for a 250 6 cyl accourding to the Chassis Identification on page 8 of the LMC Trucks book.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    thanks cool, yep, i found an online decoder and thats what is said, 250ci L6
    im saving cable cuz it seems that 250 parts trucks dont exist so i beter get my 1980 250 cable now or never probably find another, the cable changed a couple or few tiems from 73-80 alone cuz of how the cable connected to carb and intake changed, i know 73 isnt same deal as 80 as far as length and where mounted to intake/carb, then 71 72 are different again too since 71 was first for cable
    thanks
    thanks
  5. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    If it helps the short 6cyl. cables are for the non-integrated head 250/292's w/ a monojet carb and the real long cables are for the integrated 250's w/ the 2bbl. carbs .
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    cool, yeah 79 apparently was first year for 2bbl 250ci engines according to parts listing lookup at parts store anyways, i have seen one in an 81 c-10, they are funky, 2bbl intake and two exhaust pipes.
