1982: 10 bolt or 12 bolt, hmm
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by R72K5, May 7, 2003.
  1. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    well ive got an 82 c-10 pickup out here and its got a 12 bolt rear axle with TAB stamping code, im not sure why or how its got a 12 bolt when 82 is supposed ot be 10 bolt
    my stepdads 82 K-10 has 8.5 axles under it, maybe its a 2wd thing, 12 bolts carried over on 2wd but not on 4x4 in 82 ?
    anyoen know why, and also what ratio TAB is for 12 bolt rears ?
    thanjks
    R
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    This has been discussed many many times. There wasn't any specific year or date that GM stopped using 12 bolts, they just started in the late 70's and had 'em phased out sometime in the early 80's. So some trucks got the 12 and some got the 10...who knows... /forums/images/graemlins/1zhelp.gif
  3. dyeager535
    26,975
    anyone know why, and also what ratio TAB is for 12 bolt rears ?
    No help whatsoever, but if anyone has an '82 truck parts manual, it will be listed there.
    My '85/86 parts manual lists 1982 rear axles, but model is "S1", while later years are listed as C or K 1,2,3. Since it lists "S1" I doubt it will be correct for your application, especially since "TAB" isn't listed at all.
  4. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I've heard of 12 bolts in 82s before, not common but it happened. I've never heard of one in anything later than 82 though... </font>
  5. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    thanjks
    R
    well my 82 has 10bolts front/rear..wish it had a 12 bolt sometimes, would be alot easier to drop a detroit in there!
    went to the junkyards today, found a bunch of 12 bolts, but it would be nice to find one already locked! anyways...
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
    That's easy. '82 was the final year that the 12 bolts were the standard axle under the K5's and 10's. 10 bolts were the standards starting in '83. /forums/images/graemlins/thumb.gif
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    interesting
    i missed that last discussion then
    i always wondered how some of the 79 or so vans had an 8.5" axle instead of a 12 bolt,
    my 81 c-10 has a 8.5" and the 82 is same truck same 52" springs and all but 12 bolt
    wierd stuff.....
    thanks
