1983ish "Flat Style" crossmember needed
Discussion in 'Parts & Trucks Wanted' started by 83ZZ502_Jimmy, Jul 23, 2002.
  1. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    1983ish \"Flat Style\" crossmember needed
    Looking for a crossmember for a 1983 era Blazer/Jimmy. This is the one for the long adapter. 208 t/case
    Thanks,
    John
  2. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Re: 1983ish \"Flat Style\" crossmember needed
    TTT /forums/images/icons/wink.gif
  3. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    arnt they the same as the 203 and 205 ?? i have a few crossmembers around i will look 4 ya and compare them up IF you are still looking
  4. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    I tried using the flat style from my 78 th350/203 in my 84 with a th400/208 it was a no go... was off by quite a bit.
