1984 gmc suburban gear ratios
Discussion in '1936-Present Suburban' started by BIG B., Jul 29, 2003.
  1. BIG B.
    BIG B. Registered Member
    Mar 10, 2003
    48
    SAN DIEGO
    First off did the 84 burb come with a 454 and if so what was the gear ratio in the rear 14 bolt. Only reason I ask is because I have a chance to purchase a set of axles out of an 84 burb but cant go and look at them until this weekend. I am real anxious to find out before I drive 45 minutes to look at them myself. thanks
  2. muddysub
    Jun 23, 2001
    10,452
    489
    my garage, Henderson, NV
    the only way a 4x4 suburban willhave a 454 in it is if its a swap in that someones done to it. gearing... either 3.73 or 4.10.
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    First off, only 2wd burbs ever came with 454's....more than likely either 3.73's or 4.10, but the true way of finding out is to pull the cover /forums/images/graemlins/thumb.gif
  4. BIG B.
    Mar 10, 2003
    48
    SAN DIEGO
    [/ QUOTE ] If it is a 2wd could I still use both axles in my 4x4?
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    if its a 2wd, you can only use the rear axle, the front axle will only have 2wd parts(looks like a car front end)
  6. Ddragggon
    Ddragggon 1/2 ton status
    Apr 25, 2001
    2,657
    Hartford, WI (formerly Etiwanda, SoCal)
    [/ QUOTE ] not entirely true on the only part. while autozone's computers refuse to admit that such a thing as a 454 bound K20 existed, I've been proven wrong by VIN's from other board members. also, Pep boy's computer admits the existance, and the mounting holes that allow either a big block, small block, or I-6 to be used kinda argue towards the fact they sold 454 bound K20's at some point, to someone. afterall, punching another hole costs another few cents, and a few cents saved over 30,000,000 vehicles is a few million bucks....
    but what do I know...
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I seem to remember '92 being a landmark year for the Burb since it was the first year you could get a the BBC in a 4x4. /forums/images/graemlins/thinking.gif
    3.21 & 3.42 are common 14FF ratios in 2wd BBC applications.
  8. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    1992 was the first year you could buy a 454 4x4 Suburban. (Rich won't ever admit it though). If this thread goes on long enough - somebody will chime in about how they used to work for a mining company (etc.) and they saw a 454 4x4 suburban that they swear came from the factory that way. Well.......maybe a special order for commercial customers could have gotten some built....maybe..or maybe a dealer did a mass swap. But......I'll still wager a fair amount that you could not order one as an individual ...ever... until 1992 (I tried my best in 1984). I will pay to see an actual vin on an actual (pre 1992) 4x4 Suburban that shows a code for a 454. If you can't produce that....the truck has nothing more than a swapped in BBC.(period)
  9. BIG B.
    Mar 10, 2003
    48
    SAN DIEGO
    [/ QUOTE ] I will pay to see an actual vin on an actual (pre 1992) 4x4 Suburban that shows a code for a 454. [ QUOTE ]
    How much would you be willing to pay? LOL
  10. azblazor
    May 5, 2001
    1,953
  11. BIG B.
    Mar 10, 2003
    48
    SAN DIEGO
    I will see what I can find. LOL /forums/images/graemlins/shocked.gif
  12. fatboy
    fatboy 1/2 ton status
    Jul 1, 2003
    290
    Tennesse
    another way to check the gearing ruffly is to rotate the wheel or drum 1 time and count how many times the yoke turns if it is slightly under 4 it is 3,73 if slightly over 4.10 just a quick clean way.....
