1985 Blazer k5 (little monster buildby ORD)
Discussion in 'OffRoad Design' started by Remember_54, Dec 26, 2011.
  1. Remember_54
    Remember_54 Registered Member
    Dec 26, 2011
    27
    Azerbaijan
    Hello Guys,
    I`m from Azerbaijan, Baku (small country in east Europe) Sorry for my
    English.
    I started this project almost 1,5 year ago. It is half done know and I want
    to show it to you and get some advices.
    I have 85 Military k 5 Blazer with 6.2 diesel (M1009). I love chevy trucks,
    specially k5.
    So i decide to build this lovely truck for off road use.
    I leave in a small country, we have very limited quantity of old
    American cars here, so there are no any cool new parts here. :( I was
    looking for the company who will provide me with all new HD parts, my
    point was to install all new parts
    I searched internet and found Off Road design.
    I decide to buy all parts directly from them. Because i was sure that
    this guys most professional than any other companies. I spoke with
    Stephen, very nice guy, he was very pleased with me, i was more than
    happy with services which they provide.
    So we decide to buy a frame of k5 and install all new cool parts on
    this frame, and after that, it can be shipped directly to my country
    like almost finished car.
    Sorry if thread in wrong place
  2. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    I start from engine:
    new 6.5L turbocharged diesel (i love diesel for offroad only)
    INTERNAL UPGRADES
    Balanced Rotating Assembly (includes new flywheel)
    Coated Pistons
    Stud & Girdle Kit
    High Volume Oil Pump
    20:1 Compression
    Ported Cylinder Heads
    Coated Combustion Chambers, Exhaust Ports, Valve Faces
    Coated Precombustion Chambers
    Fluidampr
    SCAT Crankshaft (HD Crankshaft)
    EXTERNAL UPGRADES
    Injection Pump (6.5L Turbo w/ Arctic Fuel Components)
    Injectors (6.5L Marine)
    Turbocharger Kit (6.5L w/ Turbo Master Boost Controller)
    Ceramic Coated Manifolds & Turbo Housing
    Glow Plugs (12 Volt)
    Water Pump (Serpentine Belt HO)
    Serpentine Accessory Kit (w/ New Serpentine Belt)
    * Brackets, Pulleys, Power Steering Pump, Tensioner, Etc….
    HD 350AMP Single Alternator
    AC Compressor (New) w/ Hose Adator
    HD Plastic 12 Blade Fan & HD Fan Clutch
    HD Gear Reduction Starter (12 Volt)
    Custom Paint (Marine Grade)
    Glow Plug Wiring Harness (New)
    Powder Coat (Oil Pan & Front Pulleys - Chrome Like)
    [​IMG][​IMG]
    [​IMG][​IMG]
  3. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    next step suspension: (thanks to Stephen suggests)
    [FONT=&quot]3” ORD custom front leaf springs[/FONT]
    [FONT=&quot]Front U-Bolts D60 front axle GU37051[/FONT]
    [FONT=&quot]Heavy Duty Greasable Front Shackles GU37011 [/FONT]
    [FONT=&quot]Greasable Spring Main Eye kit GU37012[/FONT]
    [FONT=&quot]Crossover steering system for GM with D60 and 3” lift [/FONT]
    [FONT=&quot]Brakelines 79-98 and D60, 10mm Brake line kit through 6” Lift GU30011 [/FONT]
    [FONT=&quot]Bolt-in steering box brace ‘81-87 GU39001-L [/FONT]
    [FONT=&quot]Custom rear leaf springs[/FONT]
    [FONT=&quot]Greasable rear spring and shackle bushings 1 ½” spring eyes and 1 ½” Shackles GU38002 [/FONT]
    [FONT=&quot]GU38015 4.5” Heavy Duty Rear Super Shackle [/FONT]
    [FONT=&quot]No bushings with this kit, bushings are included in the greasable rear kit above. ORD HD rear shackles use 1.5” bushings.[/FONT]
    [FONT=&quot]Rear U-bolts and plates for 3/4t or 1 ton axle U8021[/FONT]
    [FONT=&quot]King Pure Race Series 2,5 “ with Compression Adjuster[/FONT] & bump stops
    [​IMG][​IMG]
  4. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    Axles:
    DANA 60 front & 14FF rear
    Front Axle:
    4340 chromoly superior shafts
    CTM joint for front axle
    Core Axle
    Kingpin rebuilds
    Spindle bearing kits
    wheel bearing kits
    ujoints (806)
    reman calipers
    shop supplies
    ARB HD diff cover
    HD Tierod and ends
    HD line kit
    Diff install kit
    4.56 r&p
    ARB locker
    35 spl stubs
    Warn 35 spl hubs
    1350 pinion yoke
    Ubolt plates
    Rear Axle 14 bolt
    With 4340 chromoly superior shafts
    Core Axle
    wheel bearing kits
    shop supplies
    disc brake brackets
    reman calipers
    brakeline kit
    rotors
    dually wheel studs
    Diff install kit
    4.56 thick r&p
    ARB locker
    Heavy Duty Diff Cover
    1350 ubolt pinion yoke
    [​IMG][​IMG]
    [​IMG][​IMG]
    [​IMG][​IMG]
  5. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    NP205 Transfer Case System
    TH400 output shaft for NP205 application, sticks out from transmission housing approx 4.5”
    TH400 to NP205 adapter housing (new)
    Built NP205
    32 spline female input gear
    32 spline front output shaft
    32 spline fixed yoke rear output shaft
    ORD new shift rail option
    ORD 2 stick shifter for NP205
    CV joint driveshaft flanges on front and rear
    Crossmember
  6. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    Transmission:
    Level 3, 4L80E / Quadzilla Transmission and Converter
    along with Winter's Sidewinder Standard Shifter
    Some description on transmission:
    The baddest of the bad, this is a non-electronic 4L80E transmission. Some of the features are: Full manual shifts - the transmission will be in the gear you select and changes to any gear you choose when you move the selector, no computer or wiring needed, Red Eagle clutches, Carbon fiber band, RedEagle PowerPacks for the forward, intermediate and direct clutches, Kolene steels, Red Eagle clutches for the overdrive and overrun clutch sets. The 16 element intermediate sprag is replaced with a 34 element sprag, rated up to 1200 horse power depending on upgrades and has full throttle 3-4 up-shifts. It comes with a non-lock-up torque converter (#L80-NLU) and the core charge is included in the price. This is the transmission that off-roaders, big horse power streeters and racers have been waiting for. Something with an overdrive gear that you can beat the snot out of without giving it or you a runny nose. It just gets comfortable at 900 horse power.
  7. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    Steering column with hydraulic assist
    +Cooler for the power steering fluid
  8. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    Tires & wheels:
    Tires will be 37X12.50R17
    Wheels HD17, with BLACK RING
    [​IMG][​IMG]
  9. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    Roll cage:
    [​IMG][​IMG][​IMG]
  10. 63chevyll
    63chevyll 1/2 ton status
    Aug 13, 2009
    4,515
    Colorado Springs
    Sweet K5.
    Look forward to your progress. And cool to see a set of boggers
  11. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    5,977
    42
    San Jose, California
    Yea, I wanna see it finished.
    -Brian
  12. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    2,914
    4
    Colorado
    It's down to a really short list of things that I'm aware of, then the little detail of shipping:haha:, I,m not sure how you ship a vehicle over seas?
    To the best of my knowledge once it leaves ORD and recieved all of the work will be transfered over to his chassis. It's been fun to work on I know that.:pimp: Unless things have changed since Stephen and I last talked this is basically a donor chassis and body that works well for getting an entire vehicle worth of parts over seas. it isn't being made to run or drive at ORD.
    I'm not in on the fine details but it is a cool project. Never worked on something for an overseas client.:waytogo:
  13. bp71k5
    Mar 31, 2006
    5,977
    42
    That's an interesting way to handle the shipment. My mother-in-law sold an old Cadillac to a guy out here that buys old American cars and ships them to the Ukraine or Russia where they are really sought after. He shipped them from Canada for some reason.
    -Brian
  14. Deuling
    Deuling "Official CK5 Post Whore" Premium Member GMOTM Winner
    Dec 8, 2010
    22,097
    410
    Muskegon Michigan
    Wow some great stuff man!!!
    I want that tranny!!!:thumb:
  15. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    thanks a lot guys ... i really love this truck and now not going to offrad trips about 1,5 year. because spending all my money to this project.
    I hope the project almost finished, Stephen can update on this..when he have time.
    the problem is that our customs do not allowed cars that is less than 2000year.. that why i will need to ship my military blazer and USA blazer to Georgia which is 700 miles away from our country, and put all stuff from ORD one to military, and then come back to my country with finished military one.
    btw here the link how engine is running http://www.youtube.com/watch?v=YX1hdncMnno
  16. Remember_54
    Dec 26, 2011
    27
    Azerbaijan
    some more pict.
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  17. max 02
    max 02 N.E.D. Premium Member
    Sep 29, 2009
    7,228
    187
    Clive Alberta Canada
    That is one of the nicest 6.5s I`ve ever seen.
    Good job on your rig... it will be sweet.:waytogo:
  18. fallguy
    fallguy 1/2 ton status
    Nov 23, 2009
    341
    montgomery tx
    Very nice :popcorn:
  19. COCHEV
    COCHEV 1/2 ton status
    Jul 9, 2002
    4,057
    Washougal WA
    Wow! Just drug that thing all the way through the ORD catalog
    Sent from my DROID2 GLOBAL using Tapatalk
  20. Big Ray
    Big Ray 3/4 ton status Premium Member
    May 17, 2009
    9,612
    82
    Eastern NC
