1985 K5 Diesel
Discussion in 'Complete Vehicles' started by rustyk5, Dec 8, 2005.
  1. rustyk5
    rustyk5 Registered Member
    Aug 3, 2003
    63
    Hampden, ME
    "Stinky"
    6.2L Diesel
    700R Auto
    NP208
    10 Bolts 3.08 (according to the glovebox)
    167k (I think)
    Pw/Pdl
    $2500 or resonable offer
    New parts:
    ----Body
    New floors rear seat to tailgate
    passengers footwell
    Rear footwells
    Seat bolt holes re-enforced
    Herculined interior (black)
    Pickup truck tailgate
    Soft top
    New inner fenders(both)
    3x5 Steel "Rocker Knockers" under the doors
    Energy Suspension poly body mounts
    ----Engine
    2 New Optima Red tops 720cca
    Kennedy Glow plugs (all 8)
    Electric fuel pump conversion
    6.5 (28MT) gear reduction starter
    size 1 battery cables with marine battery switch
    New harmonic balancer 4/05
    Valve cover gaskets 4/05
    3 inch "true dual" mandrel bent exhaust with cross over pipe
    2 Flowmaster Mufflers
    ----Transmition and Transfer Case
    Rebuilt NP208
    Clocking ring
    Transfer case is currenty clocked 1.5 inches above stock placement
    Custom tranny crossmember with Energy suspension poly bushing
    B&M Quick Silver floor mounted cable shifter
    ----Other stuff
    Poly gas Tank (25gallon)
    Center arm console (with built in heater/cooler)
    Low beam headlight wiring upgrade (LMC truck)
    Alpine CD player
    New speakers up front
    Heater blower motor
    Heater core
    Windshield and windshield gasket
    Drivers power window motor
    Custom steel rear bumper
    ----Parts
    1 Old style starter rebuilt proffessionally 10/04 works fine
    2 Extra 208 Transfer Case (rebuilt and works but leaks)
    3 I have the complete weather gasket kit from JC Whitney new in the box. This kit provides ALL gaskets for both doors, I believe it cost me $200 when I bought it.
    4 Comes with Chevy's repair manual for that year (all models C/K/G vans etc.) and both Chiltons diesel repair and C/K truck manuals
    5 I have most of the stock stuff I took of and/or replaced if you want to return it to it original form
    6 I will throw in all extra oil/filters/u-joints etc. that I have in my garage. I have ALL receipts for what I have purchase for this truck.
    7 I have everything needed to convert it to run on veggie oil if interested
    ----Concerns
    1 A/c has been removed, it has working heat but you are unable to change the delivery setting.( for example vent to defrost) It blows out of all openings but hardest on the floor
    2 It has cruise control but has never worked as long as I have owned it
    3 Dome light has never worked (wiring)
    4 Top does leak a little bit when it rains real hard. It doesn't drip on passengers or anything and the floor is waterproof so I havent really messed with it.
    5 It has o.k. tires 265/75/15 =31's 3 diff brands
    6 It has been starting hard as the cold weather has hit the area. It only starts hard after sitting for more than 5-6 hours. I have not experimented with it plugged in and I think that is what it needs.
    7 PDL will lock but not unlock
    This truck runs great ,once you get it started:haha: , and burns no oil. I get 16-17mpg in town and as high as 24mpg on the highway. The passengers and rear bench seats are mint. The drivers is ripped but I am currently running a seat cover. The dash it cracked and dry rotted. Its previous owner rubbed against something white on its passenger side and someone didn't like the previous owner and keyed the driverside. I have spray painted the truck in various places to fix rust etc. It doesn't look bad but it wouldn't make the cover of 4 Wheeler. It ran great all spring and summer and the starting thing has me upset, but I'm hoping that plugging the block heater in will make all the difference. It is registered and inspected in the state of Maine.
    I bought the truck on 6/9/03 have spent alot of money and more time that I care to think about on this K5. I have some life changes that are going to impact the amount of time I have to tinker. I hate to see "Stinky" go but I'm sure I can find a good home. I could part "Stinky" out and get more than I'm asking but I'd like it to go as a whole blazer to someone that will continue to improve it and drive it. I will also list this locally in the want ads.
    I know I'm forgetting things and I can provide any info you need (including pictures) if you let me know.
    Thanks again to all the CK5'ers that helped me along with my project;)
    Andy
    Hampden, Maine
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
  3. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    I don't have them posted on the net anywhere to link them to this forum. I can email them directly to you if you're interested. Would you really come from VA for this?
    Andy
  4. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    probably not, but im curious and im sure others are too. i really would love to have a diesel k5 tho
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
  6. 79k20350
    Nov 22, 2004
    7,757
    Ct
    ok, i definelty want it. :D i need a diesel, adn this look to be the one. where in maine are you? how long till you need to get rid of it? thanks man!
  7. rustyk5
    Aug 3, 2003
    63
    Hampden, ME
    Sorry I took so long to reply, the holidays are always a crazy time for me:crazy: . I have replied to your P.M. :wink1: check you're mail.:D
    Andy
  8. 79k20350
    Nov 22, 2004
    7,757
    Ct
    i didnt get it, try again?
  9. 79k20350
    Nov 22, 2004
    7,757
    Ct
    nevermind, i checked my pm's first. then i checked my email:D
