1985 Military M1008 Chevy Truck front Dana 60 into 88 Chevy Blazer
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by pomai, Jul 13, 2003.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Will a 1985 M1008 Chevy Truck front Dana 60 be a bolt into a Full Size 88 Chevy Blazer? What about the steering and springs? Thanks Ed
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes it will be a bolt it, you may need a conversion ujoint, not sure what size they are. you will need new u bolts, though
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    U-joint will be the same size from the D60 to your stock shaft. Both share the same 1310 series yoke size. /forums/images/graemlins/thumb.gif
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Has anyone had problems getting those two bolts out on the passenger side? That's what worries me most about swapping in my '60, I don't have a torch.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Knock on wood, but I've never broken one yet. I did buy a salavage yard D60 with one broken in it once. Just got a drill and did a small hole into it and used an EZ-out after applying some heat to it first. Came out easily. /forums/images/graemlins/thumb.gif
  6. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    I broke one of those two bolts on the Dana 60 that was in my GMC K-3500 . It snapped right at the spring pad surface when I was removing the bolts. Even with all the care that I could give I broke an easy out off in it .
    I suggest using a penetrating oil that will soak in before you loosen those bolts ( something industrial strength like " Free-All ") .
    HTH , Tom
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    If the ez-out fails, just take a largish nut and place over the bolt remains. Weld through the nut hole and make sure you weld the bolt (and potentially broken ez-out) first to get good pen, then tie in the nut. Let cool, and it should come right out. That gives very intense heat and relatively localized, it will free up most any bolt... I’ve also built up a nub on smaller bolts to get hold of with a vice grip, or grind flat for a crecent…
