1986 body lift questions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kargan, May 4, 2003.
  1. kargan
    kargan Registered Member
    Apr 5, 2003
    5
    Gentlemen,
    I'm considering purchasing a 1986 Blazer. Truck is in pretty good condition with a Rancho 4 inch
    suspension lift AND a three inch body lift. Both look like they were professionaly installed. How
    tough will it be to take out the three inch body lift? Truck is an automatic. Also, how do the '86s
    hold up compared to, say a '89 or '91? Any problems with the 208 transfer case or the 28 spline
    10 bolt axles? Also, any regrets regarding a non-fuel injected 5.7 engine? Keep in mind, my previous
    ride was an '86 fullsize Bronco till I cracked the frame... Thanks in advance.
    Carmine
  2. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    body lift is easy to take out. the only thing you should have to change is the shifter linkage will need slack taken out. regrets? not having FI and thats about it.
  3. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I don't think there is much difference in strenght between a stock 86 and a 90 model Blazer. The major difference is the fuel injection which some people really like and others don't. I have an 86 and since I am totally clueless when it comes to computers and fuel injection I am am happy with my Q-jet which has never let me down.
  4. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    PM me if u want to get rid of that body lift....
  5. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    In addition to the shifter linkage, you may need to readjust the fan cowl attached to the radiator. I say this cause I had to put in a spacer when I put my body lift on. However, I could be wrong. Just ask my wife & she'll testify to that one /forums/images/graemlins/grin.gif
    /forums/images/graemlins/burb.gif /forums/images/graemlins/thumb.gif
  6. txbluethunder
    Jan 29, 2002
    835
    Austin, TX
    your right BurbLover...i run electrics so i skipped that step.
  7. BlaznRebel
    BlaznRebel 1/2 ton status
    Sep 1, 2002
    115
    Louisiana,Baton Rouge
    mine is an 86 and i have no regrets except well not having a blazer when i was alittle younger...
