1986 Carb Vacuum Line Connection
Discussion in 'The Garage' started by PonchoCatalina, Jun 8, 2005.
  1. PonchoCatalina
    PonchoCatalina Registered Member
    Feb 8, 2005
    18
    College Station, Texas
    Does anyone know what the port at the top rear of a quadrajet carb connects to ('86 Suburban)? I removed my aircleaner and discovered a connection near the top of the carb and facing towards the firewall with a short (2") piece of vacuum line (about 1/8" diameter) attached to it. I cannot, however, figure out where it originally tied in - there are no obvious loose hoses in the vicinity. Could this just be some sort of overflow? If anyone knows, I'd sure appreciate hearing about it! Thanks.
  2. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    any pics?
    it might be for a choke pull-off
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    As far as I remember it went to the air cleaner connection underneath near the center .
  4. PonchoCatalina
    Feb 8, 2005
    18
    A picture is worth 1000 words...
    I posted a picture of the carb with an arrow indicating the location of the connection in question. This picture is not of the actual carb in question, so the port appears to be connected to something (unlike mine), but I can't tell what it's hooked up to. The only place I could easily host image was my cardomain.com site, so it's the last picture on the page (#8). Thanks!
    http://www.cardomain.com/ride/745344/1[/URL]
  5. mikras1
    mikras1 Registered Member
    Jul 25, 2003
    11
    CT
    If an 86 Burb carb is the same as a Blazer
    That looks like the clean air port for the EGR Bleed solenoid.
    On the rear of the passenger side valve cover, there should be a rectangular solenoid with 2 ports.
    1 port connects to the rear of the carb.
    The other Tees into the vacum line to the EGR.
    (Writing this based on memory)
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Yeah that looks like the port that used to run to my air cleaner underneath .
