1986 Gmc stepside 2x4 body to a 1973 Chevy Blazer 4x4
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by andrew86stepside, Apr 22, 2003.
  1. andrew86stepside
    andrew86stepside Newbie
    Apr 22, 2003
    I have a 86 GMC stepside 2x4 with a 4 speed trans. I have found a 73 chevy blazer that is rusted out. I was wondering if anybody could tell me if the body off my 86 stepside 2x4 will bolt on to the 73 4x4 frame. Will the frames match up? Is it a very difficult task to switch bodies? Also can I use my 4 speed from the 2x4? Thank you for your help. Andrew
  2. BRN78BLAZER
    BRN78BLAZER 1/2 ton status
    Feb 5, 2003
    133
    Stoney Creek Ontario, Canada
    I saw this done once and it was horrible. The guy tried to shorten the stepside box, while still trying to keep it looking decent-NO GO! I would strongly recomend legthening the frame if you do this. The cab will be straight forward, you just need to make mounts for the last two which sit on top of the frame, rather than outboard and level like the blazer cab mounts. Pickup bodies are relatively easy to switch, and Yes you can use the 4 speed, you just need one bracket of the pickip frame, the holes should be in the blazer frame for it.
    Good luck if you decide to proceed.
  3. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    a few people on this site have done it...if done right it looks very nice....if you're not too attached to the box, mabey you could do a custom flat bed? if thats done up the right way it'll set the truck off really nice
  4. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    This post has some of the info you are lookin for.I put a 74 C20 cab on an 81 K5.I cut 13" of the front of my stepside bed.
    Some might think its ugly (the tan one) but I dig it /forums/images/graemlins/grin.gif
  5. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Well, it used to be purty /forums/images/graemlins/thumb.gif
  6. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    More info here and here /forums/images/graemlins/grin.gif
  7. FRIZZLEFRY
    Apr 20, 2001
    3,271
    134
    Clovis CA
    Yes but it is more "functional" now ,I can fit just about everywhere /forums/images/graemlins/grin.gif
  8. T-ROY
    T-ROY 1/2 ton status
    Dec 3, 2002
    468
    Orchards, Wa
    I have done this conversion as well, although I never put a motor in it. My wife thought it was too ugly to put money into. I used a 75 frame ( if I remember right ) and the cab literally bolted right up. I used an 85 cab. I believe the stuff you have will work easily. Body lift will probably be needed depending on what running gear you use. As far as a bed goes...I cut down a 84 Blazer body to fit. All the beds are the same behind the wheel well. Just measure and cut to length. I fabbed up a front bulkhead to finish it and it looked pretty cool. I wish that I hadn't caved when a buddy offered me money for it in front of my wife. I still owe him an a$$ kicking for that.
    I have a couple pics lying around, I'll see if I can't scan them in and e-mail them to you.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/truck.gif /forums/images/graemlins/usaflag.gif
  9. JDNobodi
    JDNobodi 1/2 ton status Premium Member
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    Early second gen Blazers still have the inboard cab mounts in the middle. Sometime during 1977 GM swicth to the outside body mounts. That is my best guess since my box of Energy Suspension body mounts goes 73 to 77. So, a regular pickup cab should bolt on the 73 frame.
  10. JDNobodi
    Oct 9, 2002
    3,008
    197
    Santa Maria, CA
    One more thing. I've heard 2WD cabs have a shallower floor and may hit the tranfer case. You may need to do floor board modifications.
