1986 K5 Oil Sending Unit
Discussion in 'The Garage' started by Tonka64, Apr 2, 2005.
  1. Tonka64
    Tonka64 Registered Member
    Dec 11, 2002
    13
    Springfield, Mo
    I've had my 700R4 Trans rebuilt, all the guages were working fine before I took it into the shop, now the oil sending unit is maxed out, I dont have a clue where it is located on the engine or how to replace or fix the problem (Engine 350 5.7L)...Please Help.
    Tonka64
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    the oil pressure sending unit is next to the distributor. It is a long cylinder with a electrial conector on one side and a brass fitting on the other going into the block.Check first maby it was just unpluged.
