1987 14bff
Discussion in 'The Garage' started by JIMMY76, Jan 8, 2005.
  1. JIMMY76
    JIMMY76 1/2 ton status
    Dec 28, 2004
    209
    HAUGHTON,LA
    Im Looking Around On Ebay For The Disc Brake Conversion Mounting Plates For My 87 14bff And They All Go Up To 1986 I Asked One Of The Seller He Wasnt Sure He Said Chevy Changed Something With The Axels In 87 He Wasnt Sure Though . What Was Changed?
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I think it was either the way the shafts attach to the hubs or the drum is not bolted to the hub??
    Someone has to know for sure
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    the Drum was changed to outside the hub and held on with the rim and lug nuts rather than inside the hub held on with the studs. It ends up altering the caliper spacing if memory serves. I only looked at it briefly. Some also have anti lock brakes.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    splines werent changed til 88 on some/most axle models, dunno if that includes 14 FF or not though
    hubs drums changed yeah to slip ons around 87 yep,. maybe only certain applications and years though, may not be 87 at all or not all of them,
    good luck
  5. sweetk30
    Nov 1, 2004
    25,537
    536
    horseheads , ny 14845
    axle info
    splines are the same . i have a gov lock from a 78-80 14ff in my dd that is a 96 14ff went in no problems. as for the brake kit it might be possible to use the older hub assy on the newer axle , but not sure . i was going to try this with mine soon.:cool1:
  6. JIMMY76
    Dec 28, 2004
    209
    HAUGHTON,LA
    ok thanks i went out and looked at it the drums are held on with the hub bolts well im going to order them ill keep you guys posted to what i find out
