1987 auto tranny and 1992 auto tranny the same?
Discussion in '1992-Present Chevy & GMC models' started by 90blzr, Apr 21, 2004.
  1. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Buddy has a 1992 suburban 4x4 with bad 700R4/4L60 in it (non electric). Would a 700R4 from a 1987 blazer be the same/work? /forums/images/graemlins/dunno.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yep, they are the same.
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    thought the OD needed input from the ECU?
  4. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I thought the full electronic 4L60E transmissions came out in 94. Before that, all 700R4 and 4L60 transmissions are basically the same.
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    nope it needs nothing to shift to overdrive. the tranny will need a signal from the ecu for converter lockup, but 87 and 92 are EXACTLY the same for wiring, and just about everything else
    the 4l60E came out in 93.
  6. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    Yeap i before i swapped in a built TH350 into mine i had my 700R4 unhooked from the ecu b/c the lock up was going crazy.
