1987 GMC oil pressure problems
Discussion in 'The Garage' started by Steve GMC, Apr 11, 2007.
  1. Steve GMC
    Steve GMC 1/2 ton status
    Dec 3, 2005
    247
    middletown,Connecticut
    like the title says oil problems. 1987 GMC k25 tbi. anyway since we've owned the truck the oil press always said 60. put thats the problem. see as soon as you turn the key it says 60. w/o the engine running. so i looked and couldnt find the bell shaped oil press. senscor so i figured its the one behind the distributor (im used to carbed engines). wrong one and my dad already replaced that one. so i went to the auto parts store and he told me to look right by the oil filter. i did and it was there. unhooked. so heres what i thought...
    if it was unhooked and was still reading 60 then the sencor cant be bad. i thought maybe the guage was bad so i put another one on. same thing goes right to 60. could the diagram behind all the guages have gone bad for just that one guage? any help is greatly appreciated..
    Steve
  2. isaac
    isaac 1/2 ton status
    Aug 9, 2004
    168
    i had the same problem. i tried 3 different gauges before i finally broke down and bought that sensor by the oil filter. i swapped it out and it worked like a champ. try that its a $20 dollar sensor at napa. hope this helps...
    isaac
  3. cabledawg
    cabledawg Secret Squirrel Premium Member
    Sep 12, 2006
    2,647
    Highway to Hell
    Sounds to me like the gauge cluster circuitry is bad. If the sender was unhooked and the gauge was still reading, and a new gauge didnt solve anything, then you have your answer.
