1987 s-10 truck, idle problem.
Discussion in '1983-2005 S-Series models' started by 55Willy, May 11, 2002.
  1. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    My dad has a 1987 s-10 truck with the 4 banger and 4 spd. problem is when you start it all it does it peg out the rpm's, or you can be at a stop sign and have it rap out again or it can fall on it's face and die. We've replaced the computer and chip and the halifex(sp?) switch down in the dist. twice and we also did the fuel filter.
    The only thing I can think of tis the trottle body, is there a good cleaner to use or is there an idle adjustment sensor on it??
    TIA
  2. Redfrog
    Redfrog 1/2 ton status
    May 4, 2001
    753
    IL
    try to clean or replace the TPS switch or the map sensor A buddy of mine had the same thing happen in a s-10 and thats what he did to fix it. I just can't remember which it was
  3. 55Willy
    Jun 2, 2001
    9,946
    Keizer, Or
    K thanks, maybe I can get that rig out of here too...woohoo room for more to come home,LMAO
  4. 350S10NJ
    350S10NJ Registered Member
    May 16, 2002
    32
    Southern New Jersey, USA
    The TPS sensor is known for that.
    Also check the IAC (i-ack) sensor it controls the idle
  5. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    Jeremy has lost his connection for a short while but wishes to know where those censors are located.
  6. 350S10NJ
    May 16, 2002
    32
    They are both on the throttle body.
    TPS is on oppsite side of the throttle cable.
    IAC will be in the front or the rear, will stick out 3/4 to 1 inch and has 2 screws and 2 pin plug
