1988 5.7 EGR Vacuum Lines
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Irish Wake, Jan 19, 2007.
  1. Irish Wake
    Irish Wake Registered Member
    Jan 15, 2007
    44
    Georgia
    Hi, I just bought an '87 K5 Blazer 5.7. It passed the smog test but it's missing the vacuum line off the EGR valve and also the lines that attach below the air cleaner snorkle. There's a selonoid there with 2 vacuum ports but no lines.
    Can anyone help me figure out why they might be missing and how to replace them. The truck runs great and passed the smog test with no problems.
    Also, the check engine light come on once in a while and resets as soon as you cycle the key.
    Randy
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    the solenoid you are refering to is probably the egr solenoid, that goes to the egr and one to the tbi.
  3. Irish Wake
    Jan 15, 2007
    44
    Georgia
    Thanks Jason, Do you know of a diagram that shows where the hose hooks into the TBI. Should I reattach or leave it alone?
  4. SLOK5
    SLOK5 1/2 ton status
    Apr 25, 2005
    216
    SAN LUIS OBISPO CA
    I could fax you a print out of the diagram from my all data program....it wont allow me to save it as a picture and no scanner here at work. Otherwise it would be tomorrow for me to help. Brian
  5. dyeager535
    26,982
    191
    Should hook to any constant vacuum source, as the solenoid (via an ECM signal) is what controls what/when vacuum actually gets to the EGR valve.
